Z06 MAFf use on a LT1
Old Sep 18, 2002 | 01:06 PM
97FormulaWS-6's Avatar
I've been doing some research and it looks like the 6.0L/LS6 MAF can be used on the LT1 with some mods to the PCM and wiring. Size of the unit being the only issue that I can see (4" inlet, 3.5" outlet). Also the cost, <$100 for the part, which is a ton cheaper than factory replacement. I'm just wondering if there is any unforseen problems that I may run into by swapping the unit in???
Mike
Mods: I put this in here beacuse from the little amount of info that I could find, most people in LT1 tech would be totally lost, let alone have any useful info.
Old Sep 18, 2002 | 02:59 PM
Kev@ramchargers's Avatar
Supporting Advertiser
through 1/28/03
You can also use a Maf translator to do the calibration, also we offer a harness that will allow you to plug in with no splicing.
Hope this helps
Old Sep 18, 2002 | 03:14 PM
FRDnemesis's Avatar
I have one on my 95Z that I purchased from Ed Wright while he had my PCM to do some tuning. It is leagues above my stock ported one (fuel tables). WELL worth the money!!! I am not sure the MAFT will do what is necessary to dial it in though???
That is not my area of expertise. How much are the MAFT's these days anyway?
Jeff
BandDirector Blk98ZM6
Feb 20, 2015 07:42 AM
hotrodyou1
Dec 20, 2014 10:05 PM
ChrisFrez
Dec 7, 2014 06:01 PM
Hot Rod Hawk
Aug 30, 2002 10:12 PM
Camaro90RS
Jul 23, 2002 07:57 AM
