fuel injector size
Old Apr 21, 2004 | 01:58 PM
SteveLT1's Avatar
fuel injector size
I have a 1995 formula lt1. The motor is a 355 ci 9:1 compression,ati p600b with 2 core intercooler...10 or 12 lbs undecided as of yet, mild work on stock heads..I dont have the cam specs but were per rskrause recommendations. i currently have 24lb bosch injectors. Was wondering what size injector i should go with. Am hoping to have approximately 500 hp at the motor. Thanks for the help
Steve
Old Apr 21, 2004 | 02:08 PM
stealth2's Avatar
50 lbs.
Old Apr 21, 2004 | 02:12 PM
SteveLT1's Avatar
is an injector of that size really needed? im still using the stock fmu and a piggyback fuel pressure pump supplied by ati in my supercharger kit. if i go that size injector, will the car..be sloppy down low rpms or does a 50lb injector just have the ability to flow more...thanks
Steve
Old Apr 21, 2004 | 02:16 PM
stealth2's Avatar
No, it can be tuned to be drivable at all rpms.
The #1 rule I've learned with my LS1s is to buy more than you currently think is required.
Old Apr 21, 2004 | 04:00 PM
SteveLT1's Avatar
ok thanks for the input...
Steve
Old Apr 22, 2004 | 10:11 AM
mongse_1's Avatar
With 500hp, you would be borderline for 42s @ stock fuel pressure. Knock your pressure up a little and you could probably get away with a 42#.
42#@ 43.5fp - 488.73hp
42#@ 58.0fp - 564.33hp
Also, with injectors this big, you can ditch the FMU.
Old Apr 22, 2004 | 10:59 AM
SteveLT1's Avatar
are there any drawbacks going to that size injector though.. for example the stock injectors i have now can handle something around 100 psi.why wouldnt a lower injector size like a 36lb/hr work if the injector can handle 100 psi etc? i'll go larger injectors..i just dont want to regret it..in any way...thanks for the advice
Steve
Old Apr 22, 2004 | 03:59 PM
john35thss's Avatar
I have 57's in my combo and it idles and drives like a stock 5.7 with a little more exhaust noise untill I spin past 3000. My 57's are almost maxed out started with 50's and had to upgrade.
57's tune like a smaller injector e-mail jack at racetonix for info.
John Carpico
Old Apr 22, 2004 | 08:35 PM
94SLUG's Avatar
If I where i would just build the system right. get 42lb or 50lb inejectors get rid of stock intank and ATI inline and fmu replace with gss340. If you need more get a boost a pump and or wire harness.
Bill
Old Apr 22, 2004 | 08:40 PM
RCF925's Avatar
Speaking of buiding it right I went with 50lber's on my 385 with 5lbs boost and was at 100% duty cycle at 5700 rpms. I went with 72#ers and the converter box which is what I should have done in the first place. They are more responsive and you get a good idle, Remeber you can't go to big
Old Apr 23, 2004 | 12:30 AM
94SLUG's Avatar
I will second that but at the time it was not in the budget.
Old Apr 24, 2004 | 10:29 AM
mongse_1's Avatar
Any high-impedance (57# and lower) will drive/idle just fine. You may have trouble on some of the bigger injectors (83# and up).
Also, most injectors won't like 100psi fuel pressure. I thought I read that the most you want to go on them is like 80#.
AdsoYo
May 2, 2018 03:21 AM
HectorM52
Jul 30, 2017 11:46 AM
QuickSilver02
Apr 7, 2015 11:12 AM
