04-13-2004, 12:31 PM
315's on 17 x 9's
I know a few people that are running 315/35's on 17 x 9's. They told me to go for it while others have told me not to. They run 285's on 17 x 9 1/2's and they say that's as far as they will go. Any opinions or experience on this subject?
__________________
http://img.photobucket.com/albums/v5...7/PA180360.jpg 96 T/A WS6 clone, A4, 3.23s,TB Airfoil, K&N with Ram Air, Comp 1.6 NSA Promags, 7/16 ARP studs, Comp Hardened Pushrods, Lt4 Springs, Descreened MAF, B&M ShiftPlus, 1LE Driveshaft, Jethot Lts, ORY, Hooker Exhaust, QTP Electric Cutout, Tuning by Madz28, 160' Thermostat.
04-13-2004, 01:12 PM
While you may be able to cram it on, it will not be an optimal performer. If you want to do it just for looks it should be ok.
I run 315's on an 11 inch wheel.
Tim
04-13-2004, 01:17 PM
I've seen 315 nitto's on stock salad shooters, looked a little weird but they hooked real nice.
04-13-2004, 01:48 PM
I've heard that people have had blow outs when cornering when using a 315's on 9 inch wheels.
__________________
04-13-2004, 01:55 PM
Quote:
I thought 315's on 17x9's sounded like a bad idea, putting them on salad shooters sounds like an accident just waiting to happen.
__________________
1997 Z/28 M6 Moser 12 bolt/4:10's, Spec 4 clutch, Spohn torque arm, LPE 3.5" DS, hotcam, p&p heads, SLP headers, Borla & some other boltons
12.019 @115.49 & 1.75 60' - 355rwhp/350rwtq (w/stock heads)
MODS
04-13-2004, 01:56 PM
i am running 315's on my 9" wheels and have never had a problem
__________________
-95 White Z28 w/t-tops: LT4 Short-block; 227/233 cam; 1:5 rr's hardend pushrods; K&N CAI; Hooker shorties; 3" all the way back; sub-frames; LT4 km; and others but cant think of them right now... oh.. and.. very very low miles on the short-block ;o)
04-13-2004, 02:00 PM
Aren't your zr1's 9 1/2 ?
__________________
04-13-2004, 02:05 PM
I have 315 Nittos on my old SS wheels for track use. They do hook great, but they do bulge quite a bit, more then I would like. I would only put Nittos that wide on a 9 inch rim because they tend to be cut a little smaller then normal 315 tires.
04-13-2004, 04:16 PM
Super Moderator
Left side - 315/35-17 BFG Drag Radial on correct 17x11 wheel.
Right side - 275/40-17 GS-C on correct 17x9.5" wheel.
http://cjcfo.fbody.com/members/injun...s/315v275a.jpg
Think about what happens when you scrunch the tire on a wheel that is 2" smaller than is recommended by the manufacturer. If you think you are smarter than the engineer that designed the tire to fit on a specific rim width, go for it.
04-13-2004, 04:18 PM
Super Moderator
Roger Grotyohann (Grotyohann headers) ran a 315 on a 9.5" wheel but I sure wouldn't recommend it
04-13-2004, 04:46 PM
What about a 285 on a 9 inch wheel?
__________________
04-16-2004, 09:42 AM
I ran 275 and 285 series tires on 17x8 eagle wheels. I didn't have any promblems. But now got 17x9.5 all around.
__________________
God is good.
1999 Z28 with lots of goodies
1994 formula
A.I.R!!3.42 Richmond,HPP III,160 stat,Borla Cat Back,BBK headers with offroadpipe 3 inch,BMR Strut tower brace,Linfgelter Cold air,TPI Air foil,Grantlli MAF,SLP IAC,Powerslots and hawk pads,TransGo shift kit,TPS Voltage MOD. 35mm ST, Revalved Bilsteins.
New best 8.57 @ 81.7 mph 1.95 60' foot.
04-16-2004, 02:01 PM
Super Moderator
Quote:
Just curious... how do you know you didn't have any problems? Were you able to verify that the tire structure was not deteriorating more rapidly from the excessive heat generated by excessive flexing of the tread and sidewall? Did you do a side-by-side comparison with a set of the same tire on the correct width wheels to verify that tread life was not reduced?
04-16-2004, 07:21 PM
Quote:
Slow Down  you arent really impressing anyone
04-16-2004, 10:37 PM
Premium Member
I have question not about rim tire fitment but whether my 96 camaro would be able to fit a set of 315 width without rubbing the inner walls on turns as the tire flexs.... does anyone know?
I was thinking of getting 18 X 8.5 in the front and 18 X 9.5 in the back the wheels have a 32MM offset... Not sure if that helps anyone hehe doesn't really help me...
__________________
1996 Z28 A4, K&N CAI, Borla Catback, 160* stat, TB Airfoil, TB Bypass, Kenny Brown DD SFC, LT4 KM, Crane 1.6 RR, Yank SY3500 TC, Hooker LTs and ORY pipe, !AIR, !EGR, !CATS, PCM4Less
Best time 07/09/05 13.297 @ 102.00 1.899 60'
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
