Old 04-10-2004, 10:22 PM   #1
dnz28
which is more effective?
Which is more effective in stiffening up a car a cage or sfc? To make things on a more level playing field compare the sfc to a 6 point cage cause that goes the length of the car un like a worthless 4 pointer.
__________________
1994 z28 lots off money spent still not fast enough.
dnz28 is offline   Reply With Quote
Old 04-10-2004, 11:27 PM   #2
ABA383
Well, the sub frames would be the most unobtrusive addition to chassis stiffness...and theres no doubt that a properly fabricated and installed cage stiffens everything, but at a cost of having to climb over it to get inside...most chassis builders would agree that the BEST way to tie everything together is to tie a 6 or 8 point cage into the subframe connectors...If you are not NHRA or IHRA required to have a cage and you are a street car I would definitely start with SFCs...if you are required to have a cage then I would still do SFCs first and then tie the cage into it...also be wary of swing out side bars...if they are not made/installed correctly, they will still allow the chassis to move, and while it may save you in a rollover it will do nothing for rigidity on your launch...hope this helps..
--Alan
__________________
1995 A4 Formula Baby Cammed 383
11.23 @ 121.18 w/ 1.52 60' on 275 60 R15 DRs
Thanks to LPE, PAF, FBC, Joe O. & E.B. Porting
http://xs218.xs.to/xs218/07340/alansigg.jpg
ABA383 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
