Old 04-09-2004, 11:15 AM   #1
Black_Z28
Send a message via AIM to Black_Z28
BMR U&L Control Arms
I'm thinking about getting upper and lower control arms for my car. I'm going to be replacing the brakes and lowering the car, so I thought now is a good time. But I was just curious if you still need to get a bushing set with the control arms? Or do they come with all the proper bushings and hardware? Also, for you guys that have them, did you notice much of a differnce in cornering stability? How much lighter are the BMRs over stock? Thanks a lot.
Black_Z28 is offline   Reply With Quote
Old 04-09-2004, 03:30 PM   #2
383Z4ME
They come with bushings. I would not spend the money on the uppers. No weight savings and no size difference to speak of. They are probably stronger all right but who cares on the uppers.
__________________
'94 Red Z28 A4, 383 w/Noszles direct port 448rwhp na
'98 Black Z28 A4, planning on a small turbo
383Z4ME is offline   Reply With Quote
Old 04-15-2004, 09:49 PM   #3
Bud M
Bud M's Avatar
BMR A arms come with bushings. But... apparently the BMR lower A arms don't match the dimensions of the stockers, they have a bend in them so they will lower the front of the car. Also BMR uses lesser quality rod ends than some other aftermarket manufacturers. If you are after better front suspension, 1LE lower A arms are probably a better choice.
Bud M is offline   Reply With Quote
Old 04-16-2004, 09:55 AM   #4
mongse_1
I agree about the uppers. As for BMR's rod ends, I'm giving mine one year and I'll probably replace them w/ QA1 Heim's. Just about everything else on my car has Heim joints and the same will apply to anything else that rattles/clunks/makes noise.
The lower a-arms are great though. A decent weight savings. I'd also suggest getting the k-member while you're at it too. That's the best chassis upgrade I made, next to my Madman torque arm.
__________________
-Methlab Racing-
'95 Trans Am: twin-turbo LT1, 9", TH400 & FOR SALE
'89 Mustang black primered coupe: SOLD
'88 Mustang LX: 8 cylinders, 4 wheels, 4 barrels, one big plate
'05 GMC Sierra: The only thing I own that isn't modified...yet.
mongse_1 is offline   Reply With Quote
Old 04-16-2004, 02:14 PM   #5
Black_Z28
Quote:
I've heard that the BMR K-Member is prone to cracking if you use it on a car that's on the track a lot. Not the drags, but a road course car. Is there any truth to this? I think I'll just want on the a-arms for now. I'll get new sway bars and a-arms in the future.
Old 04-16-2004, 02:16 PM   #6
383Z4ME
I can't imagine the k-member cracking. The amount of room it saves is breath-taking. I would recommend it.
__________________
Old 04-16-2004, 03:42 PM   #7
mongse_1
If it's built right (which BMR usually does), it shouldn't crack unless there's some unplanned force placed upon it (hitting something solid on the x-member bar for example).
__________________
-Methlab Racing-
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
