Lean, backfiring, and all of that other cool stuff
Old Sep 17, 2002 | 01:47 AM
whitehooptie's Avatar
What could this be: Back firing through intake when you press the gas more than 25%; revving it up and you can hear the car suck in air as hard as it can, almost dies until you let off of the gas, then when you let off, it revs up. You can hear it miss when it revs up. This is on my 6 cylinder by the way.
Old Sep 17, 2002 | 06:35 PM
Deadcarny's Avatar
yes, it is a lean condition since you are backfiring through the intake. are your injector values correct? is your fuel pump having any problems/filter clean? these are probably the first things i would check. if it is running fine till you give it some throttle, it sounds like more of an issue between the pickup of the pump and the injector itself, not a tuning prob. i don't know for sure.
HectorM52
Jul 30, 2017 11:46 AM
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
Chet1185
May 10, 2015 09:24 AM
grabbem88
Apr 16, 2015 06:57 PM
