Old 04-08-2004, 06:30 PM   #1
kissel
SSBC front brake kit, bolt on 1st gen....
I just installed the SSBC aluminum bolt on brake kit for my 69 camaro (a180-S) and I used auto speciality cross drilled/slotted rotors. It says that you should drive carefully and break the pads in slowly so that they do not glaze the rotors.
I went out and drove them a few miles and have a terrible squeak coming from the fronts. Kind of comes and goes. I am assuming that the squeak should go away in the near future. I also changed all the brake lines to the stainless steel and am going to get the lines power bleeded (blead) tomorrow.
Anyone ever try this application and get this squeaking. The pads that are on the car are the green SSBC pads that came with the kit and when I ordered them from Summit they said that it is the proper configuration.
Hoping that the squeak goes away...maybe when I drive the car tomorrow they will set in a little better....
hopeful-
kissel
__________________
1969 Camaro 396 SS X-66
Fathom Green 4spd
http://www.cardomain.com/ride/676916
1967 RS Convertible Project
http://www.cardomain.com/ride/2960049
kissel is offline   Reply With Quote
Old 04-16-2004, 10:42 AM   #2
kissel
Well the squeak is going away as the brakes are settling in.
Even after bleeding them by hand a few times the vacuum bleed is the way to go. The pedal is real hard, doesn't take much air at all to make them soft.
Gotta love manual brakes!
__________________
Fathom Green 4spd
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
