Adj. panrohd bar
Adj. panrohd bar
alright i bought an adjust panrod bar and its suppose to center the axle and make it that the wheels are sticky out of the wheel well equally well when i took it to the shop and had it alighned i adjusted the panrod bar until the computer said that it was aligned and one wheel sticks out more then the other whats up with that?
any suggestions
should i make it so that both are equal , but then the rear wont be aligned
what should i do????????????
Kyle
any suggestions
Kyle
doesnt that mean that something in the front isnt aligned?
I'm not really good with how the alingment machines work, but to me that would be the only way, as there are only so many things holding the rear, and not many control alignment.
theres the phb, lca, shocks, and tq arm...... phb is really the only thing that controls the alingment.... unless you have adjustable LCA's
1/2 - 3/4" is how they come stock. Bumping the rear over 1/4 to 1/2" won't ruin the alignment. The adjustment is only lateral and wouldn't even be noticed except you'll feel better knowing its centered.
Mar 13, 2016 03:37 PM
Aug 5, 2015 08:35 AM
