Old 04-07-2004, 06:29 PM   #1
kerberos
Question To get good handling after lowering the car.
I have a 93 camaro, and it is unfortunatly lowered on the worst kind of way; the springs are chopped. The car is very low especially in the front. I have compared it with another camaro with Eibach 2" drop springs, and my car seems to be 0,5 inch lower.
I'm going to get some new eibach springs. What else should I buy to get rid of bump-steer and make it go nice in turns?
Adjusteble panhard rod? Relocation brackets? Shocks?
Thankful for answer /Bjorn
__________________
Stock Camaro Z28 -93 M6 T56 M29
kerberos is offline   Reply With Quote
Old 04-07-2004, 06:32 PM   #2
cndctrdj
Send a message via ICQ to cndctrdj Send a message via AIM to cndctrdj
i got the lowering kit form thunderracing.com and it came with the new adjustable panhard rod cause you need one when it is lowered and lca relocating brackets. if i were you i would go and get new LCA's and new shocks. it will even everything off under thier that might have gotten ruined while the car had chopped springs.... anyone else know of anything i missed?
__________________
95 trans am
06 cobalt ss/sc
07 cobalt
92 turbo 240sx
92 s10
cndctrdj is offline   Reply With Quote
Old 04-07-2004, 06:35 PM   #3
americanmusscle
When you lower the car you usually need sway bars and lower control arms in the rear. The other mods you said will help out as well as getting a better torque arm. All that will definitly improve your handling.
P.s. Also some sub frame connectors will help also
__________________
2000 Camaro SS 6spd.
SLP Lid, True duals w/ Bullets ,BMR Subframes,
QTP 1 3/4 long tubes, Rear Eibachs, BMR STB, BMR Adj. TQ Arm
americanmusscle is offline   Reply With Quote
Old 04-07-2004, 07:13 PM   #4
kerberos
Thanks for the answers!
I think I know what to do in the rear now, but is there something that can reduce the bump-steer that occurs in the front? Is there someting else to do then raising the steering gear?
__________________
Old 04-08-2004, 06:29 PM   #5
cndctrdj
what exatcly do you mean by bump steer?
__________________
95 trans am
06 cobalt ss/sc
07 cobalt
92 turbo 240sx
92 s10
Old 04-08-2004, 06:38 PM   #6
Loony
Are you sure you have bumpsteer because its lowered? I'm not sure if its because of the chopped springs or not but, usually you get bumpsteer from getting in an accident.
Bumpsteer is when you hit a bump, the suspension compresses and makes the wheels turn to one side due to the steering rack not being lined up right. Kinda hard to explain without a piture...
__________________
Quote:
Originally Posted by GUTTERbOY View Post
I was a bit frightened at first, to think that something with that kind of girth had actually passed through my rectum.
Loony is offline   Reply With Quote
Old 04-09-2004, 04:24 PM   #7
97RedT/AWS-6
I've seen bump-steer tie rod ends on the rksport website. I'm not sure who else sells them. Says you need an alignment specialist familiar with bump-steer adjustments.
__________________
'97 Trans/Am WS-6 SLP headers, SLP sub-frame connectors, Wilwood 4 piston front/rear calipers with 13" rotors.
Now available with S-Trim!
97RedT/AWS-6 is offline   Reply With Quote
Old 04-09-2004, 07:10 PM   #8
Janny
Get a good set of springs for sure. Probably an Eibach Proline, or some such thing. Get a good set of shocks to match the springs. If you have lowered only about 1-1.5 inches you can get away with leaving the rest alone, but I would recommend the rear LCA relocation brackets. Makes for a nice improvement in traction out of corners. Unless you are into hard core AutoX and/or road racing you will not likely get much value/dollar for other mods. So, save your money.
__________________
'95 Z28
35/21 mm sways, MAC SFC/STB, KN FIPK, Random Tech Headers, B&B Triflow Cat Back, LT1 Edit, 3.73:1 Gears, SLP Level II Susp., CC 1.6 RR, LT4 Hot Cam, !A4, SPEC 2, B&M Ripper, Torsen T2R, Recaro Seats, Turn One PS Pump, LS1 Brakes. Plus a bunch of stuff I've forgotten. Best 13.1 @ 109, Dyno 338 rwhp/340rwtq
Janny is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
