Old 04-07-2004, 01:06 PM   #1
re1080
Send a message via AIM to re1080
lowering springs
i've narrowed it down to either BMR or Hotchkis mainly because they only lower the car an inch and i want to get lt. I've also been looking at the KYB AGXs are they good shocks? any info would be great thanks in advance
__________________
Ralph
96 z28 6sp, moroso cai, borla cat back, pacesetter lts ory, msd digital 6 and blastercoil, pcmforless tune, pro 5.0, slp steel billet flywheel, hotchkis sport springs, panhard bar and sfcs, bmr torque arm and lcas, 17in chrome C5 wheels
04 saturn Ion Redline B+G lowering springs
3inch cat, aem sri
best 1/4 14.6@96mph
re1080 is offline   Reply With Quote
Old 04-07-2004, 06:37 PM   #2
cndctrdj
Send a message via ICQ to cndctrdj Send a message via AIM to cndctrdj
i have the eibach lowering springs and kyb gas adjust shocks... they are too soft. i like to hit corners hard and they just seem to give a little too much.do a search on shocks and see what the other options are unless you like a comfortable ride?!?
__________________
95 trans am
06 cobalt ss/sc
07 cobalt
92 turbo 240sx
92 s10
cndctrdj is offline   Reply With Quote
Old 04-07-2004, 11:11 PM   #3
Robs97Z28
there is a better way to lower your car and spend less money and get better shocks.
You can run Konis in the front, shich allows you to lower the car about 3/4". In the rear you can run revalved Bilsteins (to save alittle money) or Konis. To lower the rear about 1/2" by removing a spring isolator and replace with a thinner peice of matieral. Like a peice of fuel line, cut out so it will warp around the spring.
You will save money have a better ride with much better shocks. The best part is, you will have the extra cash to buy a 35mm hollow front bar, so you can really rip around those corners.
__________________
30th Anniv. M6, T-TOPS, SLP headers, Borla cat back, afpr, 1.6 mags, 1LE elbow, SLP cai, air foil, Delteq ignition, MADZ28 tune, B&M shifter, 200 amp alt. Koni fronts, revalved Bilsteins rear, 35 mm hollow front bar, 3 Gen rear sway bar
Robs97Z28 is offline   Reply With Quote
Old 04-08-2004, 07:18 PM   #4
cndctrdj
how much do the sway bars run
__________________
95 trans am
06 cobalt ss/sc
07 cobalt
92 turbo 240sx
92 s10
Old 04-10-2004, 02:51 PM   #5
1stls1
Sway bars cost all diff $$,just depends on from who and what.Check out sup venders on that.If I lower my car 1"-1.5",would I need the relocating brackets and such?
__________________
09 Z28 factory stripped down race car.
1stls1 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
