Old 04-03-2004, 09:12 PM   #1
6speedZ28
C5 Vette calipers direct bolt on to an f-body?
I know you can't use the C5 rotors without using the relacation brackets. However I like the look of the red Z06 Calipers and was told that those would bolt right on and I would be able to use them with my stock f-body rotors. This true?
__________________
2000 Cadillac STS...leanin in the "lac"
1998 NBM Camaro SS A4--All GM and SLP options. SLP lid, K&N, smooth bellow, upgraded valvetrain, MTI T1 cam, Flow Tech LT's, ORY, Mufflex 3.5in single out cat back, DMS lowering springs, SPEED Inc tune.
6speedZ28 is offline   Reply With Quote
Old 04-03-2004, 11:39 PM   #2
1stls1
I would love some info as well. I heve seen a link for the brackets, but I dont know who has them. It is a great upgrade for low doe. I agree about the cal good looks, but I want the whole set-up. Anyone w/ some info
__________________
09 Z28 factory stripped down race car.
1stls1 is offline   Reply With Quote
Old 04-04-2004, 11:42 AM   #3
steelerfan
check out www.VBandP.com They might have what you're looking for
__________________
99 Z28 6 speed,flowmaster cat back,k&n filter,SLP cold air kit, lid,strut tower brace,& short throw shifter,Lakewood LCA'S,SFC's,drilled & slotted rotors.84 Camaro V6,stock,one owner
steelerfan is offline   Reply With Quote
Old 04-06-2004, 06:08 PM   #4
Florida_Z28_Boy
Member
Send a message via AIM to Florida_Z28_Boy Send a message via Yahoo to Florida_Z28_Boy
Are the Vette brakes really that much of an upgrade to be worth that? I dunno if I'd go with those or just a whole aftermarket setup. Anyone ever done this swap and wanna chime in?
__________________
Eric Powell
No Camaro yet, but I'm workin on it!
(Donations can be sent to the Give-Eric-a-Camaro Foundation, Largo Florida) LOL
Florida_Z28_Boy is offline   Reply With Quote
Old 04-06-2004, 09:08 PM   #5
1stls1
I have heard the conv only costs around $800
__________________
Old 04-07-2004, 03:19 PM   #6
Grover
Grover's Avatar
Quote:
Compared to normal LT-1 front brakes the C5 brakes are a HUGE improvement. The rotors are a full 2" larger in diameter.
__________________
Chad Beebe
SOLD: '97 T/A WS6 M6 Dark Metallic Green
My Car Featured in the CamaroZ28.com LIMITED 12-Month Calendar - Version I
Faster than some, slower than others
Grover is offline   Reply With Quote
Old 04-07-2004, 03:54 PM   #7
2MCHPWR
c5 calipers are roughly equivalent to LS1 fbody calipers. slightly more rigid. the main benefit to switching over to c5 stuff from LS1 fbody stuff is the larger rotor.
its almost an inch bigger in diameter and that gives the caliper more leverage when applying braking force. and since rotor is bigger, it dissipates heat much better. the bracket to mount the larger rotors is out of production, but in this thread, they are trying to get enough interest so they can make one last production run:
http://www.camaroz28.com/forums/showt...hreadid=246905
__________________
www.Ponycars.Net
1993 mazda rx7 with LS1
10.97 at 127 on radials
2MCHPWR is offline   Reply With Quote
Old 04-07-2004, 04:49 PM   #8
Grover
Grover's Avatar
The caliper is also pressure cast instead of gravity cast therefore giving it better rigidity and less flexing which means better braking.
__________________
Chad Beebe
Old 04-08-2004, 01:40 AM   #9
lateapex
In addition to the larger diameter for increased mechanical advantage and greater mass for increased heat sinking, the C5 rotors are also directionally vaned (F-body rotors aren’t). This increases pumping efficiency so more air is forced through the rotors to dissipate more heat, more quickly.
The C5 calipers also have full width bridge reinforcement (stiffening ribs). This, along with the pressure casting, increases the initial stiffness, AND the long term fatigue resistance of the caliper, especially in a high-heat competition context. This means less caliper spread (deflection), which reduces pad taper, and provides a firmer pedal. The C5 caliper also uses smaller diameter pistons than the LS1, which provides an even firmer pedal.
__________________
'94 Z28 with C5 front brakes and road racing stuff
lateapex is offline   Reply With Quote
Old 04-12-2004, 12:38 PM   #10
supermo26
I did the C5 Brake conversion. I got my brackets from Chris (unknown last name) and Bob Bishop. I don't recall the bracket price but I got all the GM stuf from Jason and saved a little cash. Im local to Jason so I didn't have to pay shipping.
I like the brakes but I must say tracking all the braided lines was a pain in the butt. C5 up front and LT1 in the back. Different types of flares and such on the lines and fittings. The rubbe lines would have been the fastest way to go but I wanted to replace them all with Steel.
__________________
95 Formula 383 Stroker AFR 210. comp cam Acell 300+ K&N CAI. Hooker LT's mufflex 3in catback. LT4 KM, Intake Coated by Jet Hot. 1LE intake elbow. SVO 42 injectors. Computer by PCFFORLESS. BMR sway bars, PHRD, GMS, MAF, LCA, STB,SFC. QA1 Shocks, 1LE springs. 17 Chrome Rims 275 X 40, Kuhmo tires.
supermo26 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
