amp hook up
Old Apr 2, 2004 | 07:49 PM
Hershball's Avatar
amp hook up
hey guys, i'm puting a high/low cross over in my camaro for a sub, what wire do i need to splice into???? Left, right and common, this would be great if you could help me. Its a 95 camaro with the bose system.
Old Apr 11, 2004 | 06:28 PM
redsled's Avatar
converter
if you're talking about a regular high to low converter, then what you need to
do is catch the front rt and lft speakers or the rear rt and lft speakers at the
factory amplifier. it doesnt matter if you tie into the front or rear. but make
sure you do it at the amplifier! you will get a quarter of the signal from behind
the radio since it is a bose system. if im not mistaken, with bose you can
find the wires in the rear wheel well by the spare tire......the speaker
colors are lt. green/ dark green and tan/ gray for the front the lighter
colors are the +'s....... the rear speaker wires are lt. blue/ dark blue and
yellow/ brown. on these the darker colors are the +'s....
Old Apr 11, 2004 | 09:37 PM
convertz's Avatar
your adding a sub and have an external crossover right?
If so there are speaker level inputs and power required. Tap into the rear speaker wires and run them to the crossovers left and right side. For power run it off your amps power screws. Then run the RCA cable of the crossovers sub out to the in on your amp. Your amp probably has speaker level inputs and a crossover integrated so u probably dont really need to run the X-over.
Mar 13, 2016 03:37 PM
HibachiZ28
Nov 6, 2015 12:53 AM
jackpawt883
Sep 10, 2015 08:53 PM
secbase8
Parts Wanted
Sep 8, 2015 07:11 PM
GusarskiSS
Exhaust System
Sep 2, 2015 03:51 PM
