need headlight help fast
Old Apr 1, 2004 | 04:56 PM
95camaro3400's Avatar
i only have brights on my 95 3.4, i noticed yesterday at about 1 pm that i had only 1 regular headlight then maybe an hour later i noticed i had none, ive been having to use my brights everywere i go, i can t even find a fuse for them, i looked at the bulbs and they are both good, and one was even replaced about a month ago, any help is greatly appreciated
Old Apr 1, 2004 | 06:22 PM
99blackSS's Avatar
The fuse is probably on the drivers side of the dash board.
Old Apr 1, 2004 | 06:57 PM
ive looked everywhere and i cannot find a fuse i looked under the fuse panel on driver side and under the hood, any ideas what it could be, im thinkin headlight switch?
Old Apr 1, 2004 | 07:40 PM
99blackSS's Avatar
I doubt it is the fuse because they are probably on the same fuse which would make it hard for them to go out at different times. Try using a continuity tester to see if the power is getting to the sockets.
Old Apr 2, 2004 | 01:11 AM
could it be the switch?
Old Apr 2, 2004 | 01:44 AM
user name's Avatar
listen to 99SS. think about it. the switch feeds power to the multi function switch, which feeds juice to both headlights' low beams. so if you lost something that far upstream, you would have lost both lights at once.
grab a test light and check each connector for juice. go from there.
good luck.
Novo
Jun 14, 2016 02:58 AM
football4life
Oct 4, 2015 07:48 AM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
damnyankee36
Sep 9, 2015 07:06 PM
