Weird idle
Old Mar 31, 2004 | 10:55 PM
transxtreme's Avatar
Weird *** idle
Ok fellas, My RS starts fine and when shes cold idles at 1500 for about 15 mins then she goes to normal idle speed. Is this supposed to happen? Is my IAC stuck, or need to be cleaned? No engine codes either. Shes due for a major tune up in about 1 month so maybe this will fix it.
BTW...Stock 305 TBI with no mods yet.
Old Mar 31, 2004 | 11:17 PM
lordmetalz28's Avatar
i remeber when i took auto shop in highschool my teacher explained this to me and why it idels differnetly. i think it idels smoother when the exhaust hits a certain temperature and the loop closes what loop i dont know but it closes
Old Apr 1, 2004 | 02:28 AM
Dirt Reynolds's Avatar
Sounds like your minimum air rate needs to be adjusted. Pretty simple procedure as I recall. I did it a few years ago on the L05 350 TBI a '92 9C1 Caprice I used to own.
Go to www.thirdgen.org and check the tech articles. Thats where I found quite a bit of useful info on TBI tuning.
Old Apr 1, 2004 | 10:41 PM
hmmm...Couldnt find any info on that. Could u explain the process.
Old Apr 2, 2004 | 12:43 AM
I looked again, and found this.
It was a few years ago that I used the article over there for setting the IAC (idle Air Control), but I'm not sure if the above link was the exact one I used.
Old Apr 2, 2004 | 12:55 AM
92RS305#2's Avatar
my 92 305 TBI idles at 1500 too when its cold, the only thing though is i have an open element air filter that doesnt recirculate engine air so my warm up time when its really cold is about 30 minutes of driving. one time i let the car idle in drive to about 40mph, and it fights braking. now that i think of it i should have that fixed before next winter
Old Apr 2, 2004 | 09:15 PM
Yea thats what i found but i dont think it needs to be adjusted. It idles fine when warm. If i mess with it when its cold and turn it down the 600 RPM, what will happen to it when it warms up?
Old Apr 2, 2004 | 10:53 PM
waltrip's Avatar
mine does that 2,when I pump the gas it usually stops,& comes back down to the normal Idle...............
Nayr
Mar 3, 2023 08:34 PM
93 RedBird
Nov 15, 2015 08:24 AM
Double aught
Oct 2, 2015 11:29 PM
tommalcolm
Sep 11, 2015 03:39 PM
tdigger9899
Sep 7, 2015 10:56 AM
