which vortec heads?
Old Mar 25, 2004 | 04:07 PM
silvertripper's Avatar
which vortec heads?
Im not too familiar with Vortec heads, but EVERYONE I've talked to says Vertec's are the way to go. My block is from a 74' 350 and rebuilt with Flat Tops. I'm now in the market for some heads and cam. Final hp I'd like around 350-400. Vortec heads I see LT1, L98, etc. Which heads will work best with this application?
Thanks,
Mark
Old Mar 25, 2004 | 04:38 PM
talos's Avatar
Just waiting for "Dirt Reynolds" to chime in here, he would probably the best person to talk to about vortec heads.
Old Mar 25, 2004 | 07:32 PM
Freak's Avatar
there is only one head refered to as Vortec. its a factory GM head but you are limited to .480 lift. pace sells vortecs that are modified for higher lifts for a bit more, but they are the same head.
the LT1 and L98 heads are just that, LT1 and L98
Old Mar 25, 2004 | 07:36 PM
talos's Avatar
there are many different castings of Vortec heads... some better then others.
Old Mar 25, 2004 | 08:34 PM
Zedzag's Avatar
There are only two different vortec 350 head or L31 casting #s.
Old Mar 26, 2004 | 07:33 AM
Yes, but which head is better. I understand they have higher flow ratings than say double humps or early vette heads but which Vortec's should I sink my money into?
Old Mar 26, 2004 | 09:01 AM
81Z28355's Avatar
you can call Scoggin and Dicky chevrolet, the are performance parts experts. 375hp with a small cam is pretty routine with these heads.
Old Mar 26, 2004 | 09:15 AM
Man I just called two valve shops here in Houston and both places said I was crazy for trying to get max hp from a set of Vortec's and that I should bring in my 882's and have them p&p'd and have 2.02/1.60's put in and I would be fine. WHATS UP!! I have 700.00 to spend, what heads are the best bet?
Old Mar 26, 2004 | 10:46 AM
nevermind, Im going with a set of World Products, Sportsman II's. Final... thanks for the help though.
Old Mar 26, 2004 | 02:50 PM
81Z28355's Avatar
I have sportsmann II heads on my Z. I have been told if you have a mild port job done on them you will see 40hp increase. I have a real mild cam, RPM perf. intake and a 650 carb. my 81 Z will run low 13's I have run a 13.2 on street tires, havnt had it back with the DR's on it yet.
And my heads are box stock.
Old Mar 26, 2004 | 05:25 PM
andrew_dieckman's Avatar
Try edelbrock. They make vortec heads which are supposed to be a little better than a standard chevy.
http://www.edelbrock.com/automotive/index.html
Old Mar 27, 2004 | 02:22 AM
Dirt Reynolds's Avatar
I didn't see this topic until now, but my suggestion is definitely consider the Vortecs. I run a ported set in my '77 Z, and am *extremely* pleased with the results. 400HP from a 350 with flat-top pistons is not a problem with Vortecs and a streetable hyd. flat tappet cam.
dfarr67
Apr 10, 2015 07:44 PM
dawg irocz
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:33 AM
Lakebratt
Feb 5, 2015 07:55 PM
Chris Anderson
Jan 27, 2015 08:30 AM
InfernalVortex
Jan 17, 2015 09:35 AM
