swaping in a th400
Old Sep 15, 2002 | 11:26 PM
faded93bird's Avatar
Question swaping in a th400
I want to swap in a th400 into my 93 LT1 car. Is there a kit that contains the correct crossmember and torkarm brakets? I would also like to retain my stock speedo. What size tail shaft works the best for this? Would a bolt on or slip fit yolk work better. And than of course do i need to alter the floor pan to make it fit. Also what kind of shifter is nesessary? I already have the drive shaft covered. Any other info to make this go as smooth as possible would deffintly be cool.
Old Sep 16, 2002 | 08:36 AM
aBrotze's Avatar
try this guys site...
http://para.noid.org/~lj/
Old Sep 17, 2002 | 12:39 PM
sleeperz28's Avatar
call up madman racing they sell everything for the swap.
Old Sep 19, 2002 | 05:26 PM
jimmbo's Avatar
how does it work with the stock speedo?
Old Sep 19, 2002 | 06:52 PM
zturbo's Avatar
For the stock speedo you will need the 91ish (forget exact year) 454 ss pickup truck speed sensor. I can get you the part number but i dont have it off hand. The 454 ss used a elctronic pickup in the th400 so its a bolt in and go situation
You can get a mount for the torque arm from B&M racing or the likes they are around been made for the third gen cars for conversions but i would just get a stand alone setup.
Steven
Old Sep 20, 2002 | 10:20 AM
speedmiser's Avatar
Steven
I'd sure like to get that p/n if you can dig it up.
Old Sep 20, 2002 | 11:12 AM
Daddyo's Avatar
Me too! Would like that p/n. Thanks.
Old Sep 23, 2002 | 09:04 PM
mongse_1's Avatar
Reluctor: 8655315
Pickup: 8655291
These numbers were originally posted by Brady back in March.
See, it pays to save important topics like that on your computer.
Old Sep 25, 2002 | 02:32 PM
94 NO TOP Z's Avatar
Is the 93 4L60 speedo cable driven? I used the above parts on my 94 and they worked great but, I'm thinking 93's are different.
Old Sep 25, 2002 | 09:32 PM
Brady's Avatar
Originally posted by mongse_1
Reluctor: 8655315
Pickup: 8655291
yeah, it does.
The 454 SS VSS connector part number is: 12085498
It's a no brainer to install...
Happy Hotrodding
Old Sep 25, 2002 | 09:38 PM
mongse_1's Avatar
Ahh, apparently I didn't save enough.
Hey, you got mail too Brady.
Old Sep 26, 2002 | 08:40 AM
speedmiser's Avatar
Nope, 93s arent cable driven.
Old Sep 26, 2002 | 08:45 AM
speedmiser's Avatar
Originally posted by Brady_96Z
yeah, it does.
Happy Hotrodding
So Id need
Reluctor: 8655315
Pickup: 8655291
as well as
connector 12085498 ???
or are only the reluctor and the pickup required?
Old Sep 26, 2002 | 10:12 AM
Brady's Avatar
you need:
Reluctor: 8655315
Pickup: 8655291
Connector 12085498
The new connector is needed because the plug-in is different on the pickup.
I have the aformentioned parts on my car, and the speedometer works.
Old Sep 26, 2002 | 11:12 AM
speedmiser's Avatar
Thanks for the info guys
