Need a driveshaft shortened
Old Mar 22, 2004 | 09:57 PM
Rodrigues's Avatar
I have a 3.5" aluminum driveshaft that I need shortened, is there any local places that can do it at a good price?
Old Mar 22, 2004 | 10:14 PM
SSpdDmon's Avatar
Just take it to the track, rev it up to about 5K and dump the clutch. Then take a little off one of the two pieces and weld it back together. Problem solved.
Oh wait, you already tried that...
Old Mar 22, 2004 | 11:01 PM
triumph's Avatar
Go see Bob @ Arrow truck on fort St. in detoit down by the bridge.He can do what ever you need. Steven
Old Mar 22, 2004 | 11:50 PM
Timberwolf's Avatar
I get all mine done at Precision Drieshaft in Lansing. He does a great job, is very quick and the prices are right.
But that's a bit of a hike for you...
Old Mar 23, 2004 | 06:34 AM
IDOXLR8's Avatar
I would just take it to DTS.
Old Mar 23, 2004 | 06:56 AM
Grover's Avatar
If you plan on taking that thing to the track with the Street Twin, I would just get a Denny's Nitrous Ready shaft with the billet slip yoke. It will end up being cheaper than having your aluminum one shortened, then breaking it, and then buying a new one.
Old Mar 23, 2004 | 08:22 AM
Rodrigues's Avatar
Hopefully this isn't a weak driveshaft, its supposed to handle 600+ rwhp with a manual trans no problem. Its a 3 1/2" driveshaft, spicer yoke, all spicer U joints (1330).
Old Mar 23, 2004 | 11:28 AM
Grover's Avatar
What type of aluminum? If it's the 6061-T6, it will break trust me I know first hand.
I had a 3 1/2" aluminum (6061-T6) driveshaft with the 1350 rear U-joint from Dynotech Engineering and twisted it like a pop can doing an easy launch at 2500 RPM. Supposedly their Metal Matrix Composite driveshafts are much stronger.
Old Mar 23, 2004 | 12:10 PM
Rodrigues's Avatar
Not sure what type of aluminum, 6061 isnt all that strong in the first place. This driveshaft was made by Visteon as a prototype part for a 2003 cobra... I was told 3/16" walls on it
Old Mar 23, 2004 | 05:20 PM
Dave89IROC's Avatar
I second this, I just had some shafts for my 90 Blazer done there
should be fairly cheap to shorten is too, it cost me $135 to get a steel shaft retubed, so, for shortening one, it is all labor, probably be right around $100
Mar 13, 2016 03:37 PM
Henson071
Dec 30, 2015 09:55 PM
ryanhilsgen
9
Sep 21, 2015 07:34 PM
95z_28_camaro_4_Ivan
Aug 25, 2015 03:59 PM
realistyc
Jul 28, 2015 07:32 PM
