110 vs 112 LDA?
Old Sep 12, 2002 | 06:29 PM
mastrdrver's Avatar
Post 110 vs 112 LDA?
Other than a rougher idle is there any benifit to have the same cam ground on a 110 vs 112? Also will I be able to run NOS with a 110 LDA? I dont have it right now but am looking at it. The cam I'm going to get is the XE230/236. Also if you guys have any comments on the cam or a cam with either LDA I would appreciate it.
Thanks
Old Sep 12, 2002 | 06:53 PM
kmook's Avatar
Advanced Tech Moderator
I think you are refering to LSA Lobe Seperation Angle.
Each has its own benifit, so you choose based on your application. Usually n/a guys will choose a 112 or 110 lsa which increases overlap. Forced Induction and N2O guys will usually run a 114 or wider lsa cam which decreases overlap.
For some really detailed info check this thread:
http://web.camaross.com/bb/Forum30/HTML/001039.html
But since your question is general in nature i will move this over to LT1 Tech.
G-BODYT56
Jan 14, 2022 11:14 PM
chevy94c
Nov 5, 2015 04:33 PM
Schul365
Aug 25, 2015 05:47 PM
Cam's maro
Aug 11, 2015 07:45 AM
Henson071
Aug 4, 2015 09:32 AM
