Need help!!!
Old Sep 8, 2002 | 04:40 PM
GreaseMonkey83
Guest
Posts: n/a
Question Need help!!!
Situation: i have a set up that requires 28 spline axles but i only have 26 splne axles
Set-up: 28-spline eaton posi traction unit in a 7.5" 10 bolt housing(factory) with 4.10 gears
Problem: The Eaton unit was in the discount room at the summit racing store so bought it thinking i would save an extra 250 bucks but, what i found out is that my 87 IROC only had 26 spline axles and the eaton differential requires 28. Turns out i cant take the differential back because it was on sale.
Solution: get 28 spline axles
Question: do they make such a thing? I know theres a such thing as 28 spline 10 bolt axles but they arent the right length. are there any applications that may be the same length as a camaro. like older comaros or chevelles? need help! Thanks
1987 IROC
2000 GTP
1972 Eldorado Conv.
1957 Bel-Air
Old Sep 8, 2002 | 05:21 PM
LT1 1980 malibu's Avatar
Well you have the split year carrier..Try finding an 88 up pair of axles from a 3rd gen..They will have the 28 spline count you need..
If you must have new then for around 250 or so moser will make you a set that will work perfectly after they get some basic measurements..Hope this helps..
FLUCK A SPELL CHECK<I CAN SPELL REALLY GOOD< IT'S JUST THE TYPEING THAT STINK AT!
http://phillyfabanddesign.tripod.com/parts4sale/
http://phillyfabanddesign.tripod.com/phillyfabricationanddesign/
http://phillyfabanddesign.tripod.com/PhillyFabsLT1RX7/id1.html
88 RX7 GTU, 97 Lt1/700R4,10" 3K stall, 4.30 gears,285CFM heads,12.4-1 compression, custom cam and 2700lbs...Daily driven!
Old Sep 9, 2002 | 02:51 PM
GreaseMonkey83
Guest
Posts: n/a
Lightbulb
How about 4th gen axles?
