WHat could cause a A4 tranny to slip only at WOT? Please tranny experts!
Well this is the question I have. My 94 Z28 (3:23) Only slips a WOT. During normal driving it's fine even with I get on it a little (gas pedal halfway down). Could this be the throttle body cable or maybe something I could fix with a HPP? Please tranny experts let me know!
Lift the lid and take it out the george forman grill man because its cooked..
Gonna need a freshen up on the soft parts..Dont beat it up anymore because you take the chance of hurting the hard parts wich cost money to replace when they go..As if the soft part rebuild arent already expensive..
FLUCK A SPELL CHECK<I CAN SPELL REALLY GOOD< IT'S JUST THE TYPEING THAT STINK AT!
http://phillyfabanddesign.tripod.com/parts4sale/
http://phillyfabanddesign.tripod.com/phillyfabricationanddesign/
http://phillyfabanddesign.tripod.com/PhillyFabsLT1RX7/id1.html
88 RX7 GTU, 97 Lt1/700R4,10" 3K stall, 4.30 gears,285CFM heads,12.4-1 compression, custom cam and 2700lbs...Daily driven!
you have 2 issues
Your clutches are smoked, glazed or completley gone. that is the WHAT is broken.
What is more intersting to me than, WHAT IS Broken in your tranny. is WHY it is broken.
Performance 4L60E's need the Trans Go Shift kit, CUSTOM PCM tuning that addresses apply and holding pressures, and or the TransGo Vacuum Modulator in addition to the PCM work.
A HUGE GVW tranny cooler is a good idea also.
Unless you addres the why issues you most likey will be back on the forum with the same issues in 3-6 months.
TAD out
Tad Banzuelo
SoCalSS 96' Impala SS
ProTools4@aol.com
[This message has been edited by TurboSS (edited September 05, 2002).]
TAD out
Tad Banzuelo
ProTools4@aol.com
