nitto drag radials
Old Mar 11, 2004 | 11:04 PM
2ktransam's Avatar
nitto drag radials
I just bought a set of nitto drag radials for my 00 ta. Should I use the water for my burnout or just do a dry burn? Thanks in advance
Old Mar 11, 2004 | 11:20 PM
6spdpewterZ's Avatar
Just go in to the water box, spin real quick just enough to get them wet, move up to the dry partand burn the hell out of them.......
Old Mar 12, 2004 | 02:56 AM
Klypto's Avatar
id highly recommend not going THREW it, just go around, chnces are there will be a small amount you will go through anyway, i did this last night an destroyed my rear end, so i know it got the tires nice and HOT(i have a pic of how sticky they were, and it was from 10 min after the burnout, being pushed into a rock pit..)
check the link and go to the broken car section
http://community.webshots.com/user/klypto
cory
if not on stock clutch(if m6) upgrade rear before you do what i did..(was my VERY first run) and im 100 percent stock besides for clutch, and snapped it right in half, LUCKILY my best friend is a mechanic, and still 400 with no labor just to replace my 2 rear axles... and finishing pulling the rear tomorrow, and hoping thats all that went wrong...
Old Mar 12, 2004 | 06:36 AM
robb4964's Avatar
cory
WOW you srewed that thing up . Split the axles right in half . Makes me afraid of heating up my tires at all .
Old Mar 13, 2004 | 01:34 AM
Well.. I have no broken axles yet.... still have my nittos for street..... BUT, use ET streets @ the track.. 13.2's w/ stock rear end
Old Mar 13, 2004 | 01:04 PM
formula383's Avatar
I get in the waterbox and turn the tires over just enough to get wet the go out of water and do the burnout.
Old Mar 13, 2004 | 04:28 PM
robb4964's Avatar
I dont need the water . If I drop the clutch at 2000 RPM's the tires spin like crazy .
Mar 13, 2016 03:37 PM
HAWG
Sep 25, 2015 11:41 AM
94ZinEdgewater
Sep 8, 2015 09:55 PM
