Go Back   CamaroZ28.Com Message Board > 1967-2002 F-Body Technical Discussion > 1967-2002 Specific Technical Discussion > Advanced Tech
Reply Post New Thread
Thread Tools Display Modes
Old 07-18-2002, 11:12 PM   #1
ujustgotwalkd
Member
Question cam selection help for upper end lt4 and bottom end 383 stroker?
i have a 96 formula with the lt4 upper end i finally have another vehicle and i am tearing apart the bottom end now. i am sending the heads off for porting 2.02 and 1.57 valves, also intake and head runners port matched. i have have a 58mm tb and 28 lb injectors. i want to know what stroker kit is nice to buy and what cam specs i should look to get.please help me out i am very seriously ready to buy this stuff. thanks in advance for any suggestions.
__________________
96 Formula m6,purple w/blue pearl, LT4 conversion(heads and intake ported and polished),30lb svo inj.,4.10 gears,bbk headers,borla exhuast,bbk 52mm tb,fastchip program,granitelli maf,drag launch kit, sub-frame&x-bar, pan hard, control arms, suncoast predator ram air,billstein shocks,free mods,torque arm,redline products,energy suspension kit,1.6 crane roller rockers,160 stat, LGM afpr,ngk tr6 plugs,nos 150hp dry shot, accel xtreme 9000wires,pro5.0 shifter, msd digital 6 ign. http://hometown.aol.com/ujustgotwalk...geprofile.html
ujustgotwalkd is offline   Reply With Quote
Old 07-18-2002, 11:47 PM   #2
kmook
Advanced Tech Moderator
kmook's Avatar
Send a message via AIM to kmook
This should be posted in LT1 Tech, please view: Advanced Tech Posting Guidelines Thanks.
I will move this over to the proper forum for you.
Ken Mook - 97' SS #2544
  • ?rwhp & ?rwtq Naturally Aspirated on the Stock Bottom End.
  • Stage 3 Pro Performance Heads, Solid Roller 242/248 Cam, Endur-X Lifters,
  • Jet Hot Hooker LTs, True Dual 3" Exhaust with x-pipe, and the list goes on and on...
__________________
-Ken Mook
Does this smell like Chloroform to you?
kmook is offline   Reply With Quote
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
