Old 07-15-2002, 11:29 PM   #1
SILVERZZ28
Post EGT Question
I know on most carb. small blocks the hottest temp is #6 but what about A EFI LT1 ?
I am about to put a gauge on my car and was wondering which clyinder. I would assume not 7 or 8 !
http://www.geocities.com/silvercamarozz28
__________________
1999 Ford Lightning. 684 rwhp & 925 rwtq.
1995 Z28 MAF TUNED BY RWTD 505 rwhp 470 tq N/A Nitrous direct port coming soon! LSx swap completed
SILVERZZ28 is offline   Reply With Quote
Old 07-17-2002, 11:54 AM   #2
SILVERZZ28
I can't believe nobody knows this???????????????????????
__________________
Old 07-17-2002, 12:00 PM   #3
Injuneer
Super Moderator
I've got mine on #7, but only because that's where the bung was on the "used" headers. They were off a fairly potent blown EFI LT1.
Fred
94 Formula A3: 381/TH400/N2O
Advanced Tech Posting Guidelines
Detailed Mod's List
11.513@115.59 on motor; 11.162@127.67, 1.643 60' on a 125-shot. Going with a 275-shot this year
__________________
Fred
94 Formula A3+1: 381/TH400+OD/N2O 11.1 @ 128 on a 125-shot
Detailed Mod's List - - - - Step into my office.... - - - - Trailer Queen......
Injuneer is offline   Reply With Quote
Old 07-17-2002, 12:05 PM   #4
SILVERZZ28
Thanks for the info. What kind of temps are you seeing N/A and N20. I have a similar set up.
__________________
Old 07-17-2002, 03:37 PM   #5
vtech95z
I've heard a few people running them on the #1 cylinder on LT1's.
396 Blown Stroker in the process.
__________________
396 Blown+Stroked LT4
Vortech Supercharged/Aftercooled
Sold for:
2010 Black SS Manual
vtech95z is offline   Reply With Quote
Old 07-17-2002, 03:43 PM   #6
KTamez
KTamez's Avatar
I'm considering adding EGT Bungs to all 8 cylinders before I coat my headers.. That way I can run a DataLogger and view all 8
Kurtis Tamez
LT4-396.com
97 Z28 LT4-396
94 Firehawk LT1-396
Team NW F-Body
__________________
Kurtis Tamez
Turbocharged 70 Nova SS
90 Mustang SSP Coupe
07 Jeep grand Cherokee SRT8
KTamez is offline   Reply With Quote
Old 07-17-2002, 04:11 PM   #7
Injuneer
Super Moderator
Tom Byrne picked up an 8-channel EGT monitor/recorder from an airplane engine, and put it in his girlfriends LT1.
http://www.tbyrne.com/z28/etg.html
I'll pull some logs up when I get home from work and post the typical NA and N2O temps.
Fred
__________________
Fred
Old 07-17-2002, 04:34 PM   #8
SILVERZZ28
I would think that the (2) back cylinders is not a good place for readings due to the poor airflow on the intake? That would be 7,8
__________________
Old 07-17-2002, 04:47 PM   #9
Joseph Overton
#5 and #6 are typically the hottest
__________________
94' lt1 388 ci. / th400
9.34@143.4 naturally aspirated
1.24 60 ft footbrake
Joseph Overton is offline   Reply With Quote
Old 07-18-2002, 09:56 AM   #10
Injuneer
Super Moderator
I looked at some of the logs... hard to generalize, since there are always some differences in the setup. Running one stage (125HP) of juice, and knowing it is set up rich, the end of track EGT's seem fairly consistant at 1580degF. I found one run where the bottle was way too low, and EGT tailed off to 1,423degF by the end of the track, as bottle pressure disappeared.... a fuel "quench".
I only have one log with the full hit of nitrous (275HP), and it was running lean because of TPS voltage problems, and peaked at 1,634degF before I realized it wasn't right and got out of it. I could only find one NA pass, and that showed 1,590degF at the top of 3rd gear - when the car was still an M6.
Interestingly, during the engine dyno tune pulls we (actually the guys at Second Street) couldn't find any maldistribution of air on the NA pulls, or of the air/N2O on the nitrous pulls. This is a dry system, spraying through two fan-jet nozzles in the outlet of the Ram Air airbox. The plugs seemed extremely uniform, and it was not necessary to use the individual cylinder fuel trims at all. As much as I hate the CNC Cylinder Heads, Inc. exhaust porting, they seemed to have a pretty good handle on the modifications required to the LT4 intake to get good results.
Fred
[This message has been edited by Injuneer 94FormM6 (edited July 18, 2002).]
__________________
Fred
Old 07-18-2002, 11:08 AM   #11
Joseph Overton
Fred Your living on the edge my friend 1450+ is lil high..1590 is right at molten piston stage...Try adding some fuel might suprise you I assume this is on pump gas but even still its some high recall readings you have..Are you sure its not detonating?
[This message has been edited by Joseph Overton (edited July 18, 2002).]
__________________
Old 07-18-2002, 12:17 PM   #12
SILVERZZ28
I have heard of blower cars reading 1500. They did say that was to high for that car too.
So I should stay under 1450? N/A and N20
__________________
Old 07-18-2002, 12:54 PM   #13
Joseph Overton
Yes Ideally "below" 1450 for n/a and n20 as well..ideally n20 being a lil cooler than your n/a reading.
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
