Ls1 Procharger Question
Old Mar 6, 2004 | 12:04 AM
robb4964's Avatar
Hello , I was wondering if someone could tell me what the max boost I can run on a stock LS1 engine with ATi procharger .
Also wondering what kind of quarter mile times im looking at with 6lbs and dual intercoolers .....Thanks fella's , Robb
Old Mar 6, 2004 | 04:48 PM
robb4964's Avatar
TTT -----Noone knows ? I have done search after search and cant find much Info .
Old Mar 6, 2004 | 09:27 PM
97WS6SCharged's Avatar
I think ATI claims 8 or 9 PSI on their intercooled kits. 6 PSI on an LS1 will probably get you 12s in the 1/4 depending on traction and what not.
Old Mar 6, 2004 | 09:44 PM
robb4964's Avatar
12's ? I was hoping high 11's ! I can hit 12's right now stock ,w/drag radials , easy .
If It can handle 8lb's , ill have to get the pulley for it . Im getting a 13lb pulley with it..also a 6lb . I have heard averag gains are 450hp form a stock LS1, and up to 540 with a stock ls1 . Thanks for the reply man , anyone else ?
Old Mar 6, 2004 | 10:18 PM
I meant 12's on street tires. With drag radials, 11's should be possible assuming the stock rearend doesn't give out.
Old Mar 6, 2004 | 10:21 PM
robb4964's Avatar
Im hoping to get a cam thats good for boost . I got a pretty good cam , but the lobe seperation is not good for boost . Im proably gonna sell the cam and get headers and cam w/my Forced unduction and maybe crank the PSI up to 8lb's . Its my weekend car so It wont see constant action .
Old Mar 6, 2004 | 10:34 PM
What happenned to stock?
Old Mar 6, 2004 | 10:39 PM
robb4964's Avatar
The cam is in my closet . Not in the car yet . I was waiting to put it in for when I get my headers and what not . I have to put a clutch in it , the clutch is GONE . All that HP wont do many any good if its slipping away . I already have a clutch , but Like I said I want it all done at one time .
I know the car will run a 12 , It pulls like a train . It needs to hook up first though .
Old Mar 6, 2004 | 11:54 PM
D James's Avatar
Are you doing this stuff yourself, if so you better get working, I couldn't imagine wanting to do a cam install, new clutch, headers, and charger all at once, thats alot of work to take on without a few weekends in between. Also i would sell your new cam and get one made for the charger, why go through all the work just to change it later
Old Mar 7, 2004 | 12:10 AM
Sounds like me fixing my head gaskets this week. Blown head gasket? Time for a new cam and valve train, and don't forget the P&P job on the heads while you're at it. I still have to put everything back together and strap the Vortech back on.
Old Mar 7, 2004 | 09:28 AM
robb4964's Avatar
Yeah , thats kinda what I said I was doin James . I am not going to instal the cam . I am waiting for everything to go thrue with the SC before I sell it , but it is not going in the car .
I am putting on the headers and SC at the same time . I have 2 other cars so its not like im going to be stuck w/out a ride . I wont be in a hurry , I can work on it on my days of and after work .
D1SC383LT4
Jan 1, 2016 01:56 PM
D1SC383LT4
Jan 26, 2015 01:41 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
ChrisFrez
Nov 23, 2014 10:33 AM
