335/35/17 Rear tires - PICS
Old Mar 5, 2004 | 08:44 PM
95_LT1_6SPD's Avatar
I picked up my wheels this afternoon. I bought them off corvetteforum.com from a guy about 20 mins away. They are 335/35/17 in the rear and 275/40/17 up front. Well i have read alot about putting 315's on the back, and decided id give 335's a try. I did some searching and there are only a few threads about it so i figured i would post about my experience.
Before i say anything, i will say that i know the tire choice is limited with 335's and they are more expensive. But i dont mind. When i first tried to fit them on, they were catching on the bump stop. So after i took a file to it for a few minutes, they went on pretty easily. I spun them around a few times and noticed they were slightly rubbing on the inner fender. A 5lb sledge took care of that tho
They were not very hard to install, and a few minutes pounding the inner fender and a few minutes trimming the bump stop was all it took. I managed to get a couple of pics of it, but its raining out and its 20 to 10. If tomorrow is a bit nicer i will get some pictures of it from the back and how it lines up with the fender and such.
To anyone thinking about doing this, i would reccomend it, as long as you dont mind paying a bit more for the tires.
Oh yeah, im going to have my fender lips rolled also.
http://community.webshots.com/user/dixon_toofar
Old Mar 5, 2004 | 09:02 PM
Xride's Avatar
Re: 335/35/17 Rear tires - PICS
Cant wait for that pic. they turn out great with wide tires.
Old Mar 5, 2004 | 09:47 PM
AW/whiteZ-28's Avatar
When you say you spun the wheel around to check I'm assuming that was in the air? If so how was the clearance when on the ground?
Old Mar 5, 2004 | 10:52 PM
yeah it was in the air. I will be dropping it down tomorrow afternoon. I didnt have to beat much to get them in. So i can clearance alot more. I will let you all know tomorrow evening.
Old Mar 6, 2004 | 12:47 AM
Pandamonkey's Avatar
It's difficult to tell from the pics that they are 335's........
We'll all be waiting for a rear shot of your car with them on there........
Old Mar 6, 2004 | 01:12 AM
DWray's Avatar
Yea, what he said.
Old Mar 6, 2004 | 02:32 PM
it doesnt look like i will be able to get pics tonight, its raining out and my car is backed into the garage and not enough room to get behind it for a pic. Hopefully tomorrow. I havent even seen them from behind yet
Old Mar 7, 2004 | 03:28 PM
pattymelt1285's Avatar
Looks good.
Old Mar 7, 2004 | 08:27 PM
BadRag's Avatar
295/35/18's on my 97' SS......
Another view...
BadRag
Old Mar 7, 2004 | 09:19 PM
Xride's Avatar
Another view...
BadRag
Forbidden
Old Mar 7, 2004 | 09:24 PM
looks good bad rag, we might be waiting a while for me to get some pictures. Just snowed a few inches, and wont be gone till wed at the soonest
Old Mar 8, 2004 | 02:19 AM
Xride's Avatar
the tires will do fine in the snow to take pics
Old Mar 9, 2004 | 05:41 PM
30thANNIVZ-28's Avatar
335s are cool and all but you are going to run into 2 problems.
1) Your tire is not plus sized correctly so your speedometer will be off.
2) Still not plus sized right so your gearing will also be off.
Neither will be dramatic but if you're **** like me that might bother you.
Old Mar 9, 2004 | 11:33 PM
Korben's Avatar
Ummm, what are you smoking. Doesn't matter if it is 315 or 335 or 395, nothing will change. UNless you are talking about going from 16" to 17".
Old Mar 9, 2004 | 11:51 PM
Xride's Avatar
What are you smoking?
if the overall hieght of the tire is greater will anything be off.
with a sidewall of 117mm he has 7 mm more sidewall. So he will be 14mm taller then stock. so YES his speedo and gear ratio will off.
