Coast-down lean roughness
Old Mar 5, 2004 | 05:27 PM
davepl's Avatar
With a 236/236 cam in my 396LT4 I've got most aspects of driveabilty sorted out except for one. I'm using a FAST computer and when I'm descending a very light grade I get a bit of rougher coast-down than in steady-state cruise.
I also notice my A/F gauge go lean when this happens, even though the target in these cells is still 12.5:1
It's almost like the ECM thinks I'm idling or going into pure decel, but I've set my max TPS for idle just 2% over no throttle at all.
Any suggestions on how to improve this aspect?
Thanks!
Old Mar 7, 2004 | 10:32 PM
bunker's Avatar
do you have a Decel timing table? What are you iac counts? might want to close the iac further more for decel, & maybe shut off the injectors all together while controling the decel rate with the iac. Not sure how it works with FAST though.
PopoFormula
Oct 12, 2015 04:19 PM
truecontr3
Oct 11, 2015 09:30 AM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
damnyankee36
Sep 9, 2015 07:06 PM
