Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
HELP !!!!
Old Jun 27, 2002 | 04:20 PM
macksz's Avatar
Angry HELP !!!!
Having some problems in CALIFORNIA !!!
My BAD 1996 Z is having problems passing
this F&%$ing California SMOG ! I've had
3 SMOG tests in the past 2 weeks !! My
HC's are too high (MAX is 55....I'm doing
76 to 128 depending on the station ). The state dropped the HC standard from 112 in 2000 / to 55 in 2002.
SICK !!!!!! I've done the spark plugs,wires,clean the K&N,Cleaned the fuel injectors...Friday i will change all 4 O2 plugs..the car has JBA headers and has 109,000 miles on it and RUNS CHERRY !! WHAT THE HECK CALIFORNIA !!! Could it be my DARN CATS ?? I'm not getting any check engine light,What the heck ?? Any ideas ?? Any place i can get cats for my 96 with OBD2 ??
RANDOM TECHNOLOGY IS ILLEGAL IN CALIFORNIA ON OBD2 CARS !! Been there tried that ! HELP !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Mack in SAN DIEGO
mack
1996 BLACK Z28 !! Too many mods !! 150 NOS shot !! THE STANG EATTER !!!
Old Jun 27, 2002 | 06:11 PM
wantafastz28's Avatar
Slip the guy a 50 spot when no one is looking?
Mike
Old Jun 27, 2002 | 07:42 PM
macksz's Avatar
Cool
lol.......... Wish it was that easy !
mack
Old Jun 27, 2002 | 10:07 PM
AZ94FORMULA's Avatar
Talking
I'm sure you need new cats. They don't last forever. I actually picked up HP cause mine were cloged up with years of crap. Another thing, you could be running too rich. You could disconnect one of your fuel injectors just before you pull into the testing bay. Or try adding denatured alchol to your gas tank, add 1 quart to every 3 gallons of gas. They sell it at Home Depot in 1 gallon cans.
P.S. Random Tech Cats suck! They won't out flow a stock cat.
Kurt
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
[This message has been edited by AZ94FORMULA (edited June 27, 2002).]
Old Jun 28, 2002 | 08:36 AM
Jerm's Avatar
From: You know when they Quit Suckin that something is Wrong!!!!
<font face="Verdana, Arial" size="2">Originally posted by AZ94FORMULA:
Kurt
</font>
You just helped more than him. Thanks
1996 Camaro Z28/SS
Alyssa
Proud member of the CZ28.com Laker Fan Club
AIM: RedSSJerm
MSN: gr8jerm@hotmail.com
