Mountain Arizona, Colorado, Idaho, Montana, Nevada, New Mexico, Utah, and Wyoming
Coolant temp
Old Jun 27, 2002 | 01:30 PM
RDYSTGO's Avatar
Question Coolant temp
What is your average coolant temp in the summer months during the hottest part of the day?
I run at 210* (+- 5*)
TIM.
1996 Polo Green Z28 A4.
K&N FIPK, Macs with dual high flow cats, Flowmaster cat-back, 160 T-stat, TB Bypass, Jet Power Module, fan switch, Transgo shift kit...
Old Jun 27, 2002 | 10:21 PM
AZ94FORMULA's Avatar
My car runs at 190/195 in traffic during the summer. When I'm road racing on a hot day it goes up to 210 towards the end of a 20 minute race. I need to buy a good oil cooler!
Kurt
LT4 HOT cam, GM heavy duty timing chain, Crane chromemoly pushrods, Comp Cams "R" lifters, K&N FIPK, BBK 58mm TB, ported intake manifold, ported & polished heads w/ 2.00/1.56 valves, 30# SVO injectors, MSD wires, BeCool radiator, CSI elec. pump, March PP kit, Crane 1.6:1 RR's, Crane ignition, AS&M 1-3/4" headers, SLP cat-back, high flow cat, Hurst shifter, Centerforce DF clutch, SLP flywheel, 3" alum. drive shaft, Strange 12 bolt with 3.73's, HAL shocks, Eibach/SLP springs, Granatelli STB & upper panhard rod, ST sway bars, SLP subframe connectors, Steve Spohn racing torque arm, RLCA's & lower panhard rod, Wolfe Race Craft roll cage, 13" Baer brakes, SLP 17" SS wheels, Auto Meter gauges, LT1-Editor and more... Dyno tested: 370 RWHP w/ 358 Torque http://www.geocities.com/crash607/kurt1.html
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
