When should I shift
Old Sep 8, 2002 | 02:47 PM
94foormula's Avatar
Post When should I shift
My cam peaks at 5900 RPMs, what should my shift point be? I have an A4 by the way.
Old Sep 8, 2002 | 10:28 PM
Deadcarny's Avatar
i would shift about 200 RPM after the curve starts to drop (depending on where in your power band it puts you).
Old Sep 9, 2002 | 09:46 AM
96z's Avatar
96z
I just used a program on the internet to figure out my shift points. My cam peaks power at 6100, it told me to shift at 6400 RPM.
Old Sep 10, 2002 | 07:52 AM
dayusmc's Avatar
From: Stationed at Camp Lejeune, N.C. (But Going Home SOON!)- From New Jersey
When should I shift on a Stock motor?
KYLE-SERGEANT USMC
97 Trans Am with minor mods.
EMAIL: dayusmc@marimecorps.com
Old Sep 10, 2002 | 08:05 AM
stevil's Avatar
Ever dyno?
Stock, I think it shifts at 5700 rpm. Looking at my dyno chart, my HP curve levels off at 5000 rpms, so I'll try shifting at 5200 rpms and see what happens... maybe 5400. I don't think raising it above 5700 rpms would do much on my car.
FormulaV8.com · 1994 Formula · A4 · 3.23
13.45 @ 102.5 MPH w/ 1.9 60' | 267 rwhp | 307 tq/lbs | 3535 lbs
"I know for a fact he is NOT an Easter bunny"
Old Sep 10, 2002 | 01:02 PM
stevil's Avatar
Hmmm...
Using Tunercat today, I found that my shift RPMs and MPHs seem way off...
1->2 5344
2->3 5400
3->4 5344
1->2 36
2->3 73
3->4 126
2->1 31
3->2 67
4->3 118
Those should be factory settings too.
Now I swear the car shifts around 5700 rpms, and I know the mph is around 45 at least... Are these lower numbers used because it takes a little time to shift? Should I put in my desired shift rpms and mph exactly, or should I lower or raise these? I'm thinking I'll do the latter.
Lets say I want to shift at 5300 instead of 5700, I should change 5344 to 4944? And lower the mph a bit?
Old Sep 10, 2002 | 02:16 PM
96z's Avatar
96z
Stevil,
I dont have an LT1 edit file with me but those look like stock tranny files.
What gearing do you have in the program? That will change the MPH shift points.
Old Sep 10, 2002 | 03:15 PM
stevil's Avatar
When I have time I'll upload the .lt1 and .bin, but yeah, it should be a bone stock file for my car. Car came with 3.23s and still has them, I'm not changing those. I guess I'll see what happens.
Old Sep 11, 2002 | 07:05 AM
dayusmc's Avatar
Steve- I just looked at your .bin- It is bone Stock! Those # are the same as my #'s I am still trying to figure out how to shift when I want to. Those Stock #'s are confuseing. Thae way Hal Fisher explained then to me was: The RPM #'s were the MIN RPM the car can shift out of in WOT, But the car accutuly shifts from MPH. But don't forget that the cars tach is probably way off! Does anyone have the Fomula to figure out RPM from Tire size, rear gear, and trany gear?
KYLE-SERGEANT USMC
Old Sep 11, 2002 | 02:30 PM
stevil's Avatar
For those that want my stock .bin or .lt1 files, here they are.
And for the calculator, 3rd from the bottom
n2oblkz
Oct 22, 2015 02:31 PM
WobblySausage
Oct 7, 2015 10:09 AM
Bxlt1
Sep 29, 2015 03:18 PM
marlar98
Sep 19, 2015 07:53 AM
