D1 blower and CSI pump. Do they fit?
Old Mar 2, 2004 | 10:25 AM
97TA-WS6-Con's Avatar
I just want to confirm that they are no clearance problems on the CSI water pump and the pulley or belts on a D1 12 rib.
I'm sure they are fine, but I need to confirm.
Thanks
Old Mar 2, 2004 | 11:26 AM
IDOXLR8's Avatar
I never had an clearance condition when I was running both the CSI waterpump and D1SC blower.
Old Mar 2, 2004 | 08:47 PM
tubby's Avatar
watch the fan. i ended up using two flexlites. one pusher on the front of the driver side and one puller on the pass side. this gave plenty of room for the pulley.
Old Mar 3, 2004 | 05:57 AM
IDOXLR8's Avatar
Tubby
You are correct. If you are running stock fans than you will have to modify one of the fans because of the 12 rib blower pulley.
Old Mar 3, 2004 | 10:48 AM
Just to make sure we are talking the same thing here. I have had the 12 rib pulley on the car for three years and have modified the fan shroud for clearnace on the blower pulley already.
I want to make sure that I can install a CSI water pump without any troubles.
I gather I should not have any trouble.
Old Mar 3, 2004 | 11:01 AM
IDOXLR8's Avatar
That is correct. The only time you will encounter problems is if your run a aftermarket radiator and want to run stock fans.
May 25, 2016 08:10 PM
Mar 13, 2016 03:39 PM
Sandersen511
Jan 13, 2015 03:49 PM
Camaro_Eric
Aug 8, 2002 12:21 PM
