Old 07-29-2002, 12:13 PM   #1
96z
Send a message via AIM to 96z
Post Modified A4 users, need tranny help
I went to the track recently for the first time and ran a 12.7 at a 108 mph. Ive dynoed at 350 rwhp so my mph seems to be a little down. The car has been dynotuned so all the power is there. The problem is the tune has the bone stock tranny tables. These obviously need to be changed but I have no idea what to change and how much, etc.
Would anyone be able to give me a hand?
96 black Z28 A4
GTP heads, GTP cam, bolt ons...
Mattucci Motorsports WNYFA FLFB
So far...12.7@108...need more practice...
The Z
__________________
96 black Z28 M6
Bauer Racing 383 433rwhp 420 rwtq
Goal -> Trapping 120+ NA on a college budget in style
Need a performance LS1 throttle body?
FLFB The Z
Pics
96z is offline   Reply With Quote
Old 07-30-2002, 08:02 PM   #2
s_willis
Send a message via AIM to s_willis
What do you think your tranny should be doing? Shifting sooner, later, firmer or softer? I will tell you what I know. Most people don't talk tranny stuff on here for some reason but I will share what I know!
Michigan Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
__________________
IHRA ST/666
Michigan Skip’s Flamed Z28
s_willis is offline   Reply With Quote
Old 07-30-2002, 10:32 PM   #3
96z
More or less my WOT shift MPH and shift RPM. Tranny could also shift a little harder although I already have a shift kit.
Anyone???
96 black Z28 A4
The Z
__________________
96 black Z28 M6
FLFB The Z
Pics
Old 07-30-2002, 11:20 PM   #4
Luna
What converter?
Luna is offline   Reply With Quote
Old 07-31-2002, 09:01 AM   #5
s_willis
If you have LT1edit or TunerCat, you can change the WOT shift rpm/mph section to change the shift points. You can also change the shift firmness by editting the pressure tables. Do you have the software? That's the first thing you need.
Skip
BMR SFC,LCA,STB
__________________
IHRA ST/666
Old 07-31-2002, 09:01 PM   #6
96z
Yep got the software just dont know what numbers to put in.
2800 stall and 3.42 gears.
As of right now they are
1-2 28
2-3 59
3-4 110
Hot shift MPH same as HOT MPH
Normal and HOT shift RPM 5700
Keep the reply's coming guys.
__________________
96 black Z28 M6
FLFB The Z
Pics
Old 08-01-2002, 10:11 AM   #7
OneFlyn95z28
Send a message via ICQ to OneFlyn95z28 Send a message via AIM to OneFlyn95z28 Send a message via Yahoo to OneFlyn95z28
Cool
what have you done to the motor? Where do you wnat it to shift?
The reason many do not talk A4 here is many have M6 or other trans and do not care or help.
A friend and I came up with the A$ no shift fix and I wrote the LT1 edit trans section you see on line. Go check it out there is some good info there
Ellis
Team Captain
Team North West F-Body
www.teamnwfbody.org
__________________
Ellis
"The Secret to Reliable Performance"
642RWHP/638RWTQ SAE
N/A 10.97@121 1.48 60Ft * N20 Coming
OLD TIMES**10.05@135 1.49 60Ft with an A4 to a 12 bolt hauling 3650Lbs!**
OneFlyn95z28 is offline   Reply With Quote
Old 08-02-2002, 10:38 AM   #8
96z
Quick run down of mods...
GTP stage II heads, GTP 226/230 cam, hooker LTs, 58mm TB, cutout, 2800 stall, gears, CAI..all bolt ons possible, stock MAF, sensors etc.
The cam makes power up to 6200 RPMs and I obviously want the car to go as fast as possible.
Fred LT1 first pointed me in this direction based on his success of raising the shift RPM and MPH.
In the upper RPMs my car feels like it pulls half ass and it ended up being that my car shifts way before it makes all its power.
Ill make the WOT shift RPM 6200 I just dont know what would be good numbers for the MPH.
96 black Z28 A4
The Z
__________________
96 black Z28 M6
FLFB The Z
Pics
Old 08-02-2002, 10:41 AM   #9
96z
Quote:
<font face="Verdana, Arial" size="2">Originally posted by OneFlyn95z28:
</font>
Sorry if Im asking the obvious but where is this LT1 edit trans section?
__________________
96 black Z28 M6
FLFB The Z
Pics
Old 08-03-2002, 06:55 AM   #10
s_willis
http://www3.baylor.edu/~Christopher_...ht/LT1Edit.htm
This is what he is refering to. Lots of good info. There is an Automatic trans section there.
Skip
__________________
IHRA ST/666
Old 08-04-2002, 11:28 AM   #11
96z
Thanks, Ill have to check that out.
__________________
96 black Z28 M6
FLFB The Z
Pics
Old 08-04-2002, 09:10 PM   #12
Ryan94ZA4
I am interested in the trans pressure tables. I want to get rid of the slide bump shift into second and firm up the 2-3 shift. I need to know what is acceptable for trans line pressure. I know my reverse manual 700R4 runs between 125 and 150 psi of pressure but I am not familiar with safe operating pressures on the 4L60E.
I'd appreciate any help any one can give so I know my trans will live once I add the supercharger. On top of modding the pressure and shift tables, I will be upgrading the trans a little, too.
Ryan
1994 Z28 A4, Vortech, Borla with EBorla, TPIS 52 mm TB, Hooker shorties, Electromotive SDI, LS1 brakes, AAM 3.42 rear, more.
__________________
1994 Z28 Vert. Sold the other 4 F bodies we had and are now down to 1!!!
11:1 LT4, Comp 230/236, Hooker Super Comps, CME, Meziere, LTCC, now getting a 6 speed.
Lots of Hondas....
Ryan94ZA4 is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
