You will find the shiftpoint part in the "normal mode Shift points vs MPH" or Performance mode shift points vs MPH.That would be on the first window that comes up under A4 transmission. Kickdown and hot shift (WOT) shift points go by rpm AND mph. Both values have to be met for the trans to shift.
Otherwise the trans shifts according to mph and %Throttle position.
Michigan Skip
Michigan Skip's Flamed 95
95Z28, K&N TPIS 150hp NOS & 27mpg!
MSD 6AL, Window switch,Ford SVO 24# injectors,
2.73's (3.42's to come) Edelbrock headers, Flowmaster exhaust
BMR SFC,LCA,STB
[This message has been edited by s_willis (edited July 29, 2002).]
