Old 07-26-2002, 11:49 AM   #1
1995zee28
Post lt1 edit.....shft firmness
95 z28 a4.....
any hints tips or example flash files that work in this area
__________________
"GANGREEN"
SOLD 5/18/09
1995zee28 is offline   Reply With Quote
Old 07-26-2002, 06:45 PM   #2
LWM
You have mail.
I also have a transgo shift kit in there, has withstood more abuse than I would have imagined. Shifts are really good at 1/2 or greater throttle openings, but are a bit stiff when 1/8 - 1/4 throttle is applied.
It had a bit of a problem with slipping when it got hot, but the force modulator vs temp table adjustment cured the slippage.
LWM
95 A4, SLP catback, KBDD sfc, airfoil, Vortech S-trim, 30# SVO injectors, Autometer electric FP guage, boost guage, Hotchkis STB, AS&M headers, AFPR, Vortech Aftercooler, 3.125" blower pulley, 7" crank pulley, Vigilante 2,800 stall, MSD 6 BTM, SLP 35mm front bar, SLP 21mm rear bar, LT-1 editor ... , 437hp at the wheels. --- members.shaw.ca/mackenzl/LWMsZ-28/LWMsZ-28.html ... 01 vert in the making ...
__________________
95 A4, 383 forged @ 9:1, SLP 2OTL, KBDD sfc's, Vortech S-trim aftercooled, 42# SVO's, STB, AS&M headers, AFPR, 3.125" blower pulley, 7" crank pulley, Yank 2,600 stall, SLP 35mm/21mm sway bars, LT-1 editor ... , 559hp at the wheels. --- http://www3.telus.net/public/mackenz...8/LWMsZ-28.htm ... 01 M6 vert in the making ... 6 point welded cage, Bilsteins, 35mm/22mm Strano bars, KBDD sfc, 218-222 on 115cl cam. 320 RWHP.
LWM is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
