Tunercat connection issues
Old Jul 21, 2002 | 05:11 PM
JamesN1830's Avatar
Post Tunercat connection issues
I have a 95 z28 that has the obd1 computer, but an obd2 connector from the factory. When ever I try to do flashread with tuner cat, the com port will not open. We use the same program on a 91 with no problems, and a 91 vette as well. I've tried it in DOS and windows with no luck. Why can't the laptop communicate with the pcm?
James
95 Z28 M6
-355 forged 11:1 motor and Nitrous Works Wet kit 125 shot
Old Jul 22, 2002 | 11:15 AM
robertf97's Avatar
Are you sure your cable for the 95 is good? I had the same problem and it turned out I had the ground wire soldered incorrectly in my homemade cable. Good luck.
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
DSMKilla
May 26, 2015 10:10 PM
BigWil
Mar 29, 2015 12:24 PM
Queens94z28
Dec 20, 2014 09:11 PM
tbyrne
Jul 2, 2002 05:37 PM
