Old 07-11-2002, 12:33 AM   #1
N.W. LT4
Member
Question Comp Cams 230/236 and Emissions ?
I'm doing the install tomorrow and want to know if I can get this cam to pass emissions here in Wa. State
thanks
__________________
87 WS6 T/A,With a 97 LT1,OBDI,T56,Centerforce DF Clutch,P&P Heads,2.00x1.56 Ferrea Valves,Compcams 1.6 Promag RR, Compcams 987 Springs,XE 230/236 Cam,GM Ext Duty Timing Chain.Hypertech 160* T/S,Custom Cold Air Intake,Vortech Elbow,Jet Hot coated SLP 1 3/4 Headers,Borla adj.catback,Pro 5.0,Magnecor 8.5,NGK TR55,LT4 KM,www.pcmforless.com Tuning,LS1 Driveshaft,GM Motive 3.73,Bilstein Struts and Shocks,Hotchkis LCA,Adj PHR & 1 in.Drop Springs. Soon to come: 01 Black Leather T/A interior.
N.W. LT4 is offline   Reply With Quote
Old 07-18-2002, 01:14 AM   #2
ScLeCo
Send a message via AIM to ScLeCo Send a message via Yahoo to ScLeCo
LMAO
I wouldn't bet on it, Im assuming you got headers, cats??
//BLACK 99 SS//M-6//T-Top//TR 224/224 .561/.561 112LSA//CNC Stage 2 Heads 2.08"Intake-1.60" Exhaust Valves//Volant Cold Air Induction//BBK 80mm Throttle Body//SLP Stage 1 Suspension Kit// Powerslut Rotors//Hawk Pads//Mosser 12 bolt-4.10 Gears//SPEC Stage 3 Clutch//ASP Underdrive Pulley//Lingenfelter Aluminum Driveshaft//BMR Sway Bars-Lower Controll Arms-Panhard Rod-Track Pak-Strut Tower Brace//Taylor Wires-NGK plugs//HPP 3-160 Stat//Skip Shift Eliminator//B&M Ripper Shifter//SLP LT Headers-SLP ORY No Cats//Borla Cat Back//Dynomax Bullit//ECT...
__________________
02 SS 8719
ScLeCo is offline   Reply With Quote
Old 07-18-2002, 01:26 AM   #3
N.W. LT4
Member
LYAO huh. I'll keep you posted.
__________________
Old 07-20-2002, 09:35 AM   #4
RichJ
Don't listen to the guy above. He doesn't know what he's talking about. A 230/236 will easily pass emissions...
...with a 116 LSA!
Rich
__________________
RichJ -- 95 Z28 M6 -- NA, stock bottom end, 224/230/114 cam
Best ET: 12.23@113
RichJ is offline   Reply With Quote
Old 07-21-2002, 02:17 PM   #5
CanadianZ
I have heard of people being able to get a CC306 to pass and the XE 230/236 isn't too far off of that. You will need cats for sure and a special tune that you put on as soon as you pull up to the emissions place. The car will not be able to drive with the tune necessary to pass. (if it does)
CanadianZ
__________________
1994 Mystic Teal Metalic Z28 6M
Mods: SLP 2 OTL, SLP CAI, Airfoil, STB, PHR, Hurst shifter
Dyno Run: 258 RWHP @ 5000RPM's. 304 ft-lbs of torque
CanadianZ is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
