TC error code 75?????
Tuner cat wont flashread!,error code 75!!tryed a different laptop same problem,tryed doing a search but nothing related to error code 75??.
94 Formula,A4,ported Lt4 heads/w1.6rr,AFR's hydra-rev,CC306cam,58mm throttle body,hooker Lt's /true duals,ram-air hood /granatelli mas-air,bosch 24lb.fuel inj.,Becool radiator w/trans cooler,2600Vig converter w/trans-go shiftkit,acpt driveshaft,3.73GM gears w/eaton posi,and a few other mods I cant think of at this time!!
__________________
94 Formula,A4,ported Lt4 heads/w1.6rr,AFR's hydra-rev,CC306cam,58mm throttle body,hooker Lt's /true duals,ram-air hood /granatelli mas-air,bosch 24lb.fuel inj.,Becool radiator w/trans cooler,2600Vig converter w/trans-go shiftkit,acpt driveshaft,3.73GM gears w/eaton posi,and a few other mods I cant think of at this time!!----SOLD!!!!!
