Old 07-19-2002, 06:33 PM   #1
dasmoothtalka
Member
Post Auto X ray
will an auto x ray perform basically the same functions as a scanmaster will? also is there any difference in the handheld units and the cd program units? the particular one i am looking at is a handhel unit and Im trying to make sure it will work for what i want it for. I need it to figure out what my fuel curves are so i can adjust with a MAF translator. is this what i need? thanks
dasmoothtalka is offline   Reply With Quote
Old 07-19-2002, 11:45 PM   #2
blksunshine
blksunshine's Avatar
Send a message via Yahoo to blksunshine
Obd I or OBDII?
__________________
94 Black Z28
MOD LIST
Z28 pics
94 Formula A4
Stock
blksunshine is offline   Reply With Quote
Old 07-20-2002, 02:47 PM   #3
dasmoothtalka
Member
OBD II
Old 07-20-2002, 06:46 PM   #4
blksunshine
Quote:
<font face="Verdana, Arial" size="2">Originally posted by blksunshine:
I am not sure if I can help you because I
have an Obd I and a4. And my auto x-ray
shows these parameters.
1.Desired RPM,E
Engine RPm,
Coolant Temp,
Manifold Air Temp,
A/C Pressure,
Map Sensor (in Volts),
Throttle Sensor(in Volts)
Throttle Angle %,
Batt Voltage
Bar Press (in volts),
L o2,
R o2,
Block Learn Cell,
L block Learn
R block Learn
L integrator,
R integrator,
L Inj. Pulse,
R Inj. Pulse,
Mass Air Flow (in gr/sec)
20.CCP DutyCycle
Idle air Mtr Pos
Learned Idle Pos
Spark Advance
Knock Retard
Knock Sensor
Egr Duty Cycle
Vehicle Speed
Engine run time
A/C clutch
A/C
Cruise control
Park/ Neutral
Brake Depressed
TCC Status
Fan #1
Fan #2
Air Switch
Loop status
Learn Control
I am sure what you want to use it for the blk learns and O2's and INJ pulse widths.
[This message has been edited by blksunshine (edited July 20, 2002).]
</font>
__________________
94 Black Z28
MOD LIST
Z28 pics
94 Formula A4
Stock
Old 07-20-2002, 08:49 PM   #5
moparman
The standard Auto Xray OBDII scan tool only does the generic stuff. You would have to get the enhanced software to really do a good job.
__________________
Artificial intelligence is no match for natural born stupidity.
moparman is offline   Reply With Quote
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
