quick wiring question on sub and amp
Old Feb 19, 2004 | 10:59 AM
Acct 23749's Avatar
I have 1 10'' type R alpine sub in a stealth box.
I believe its the 1040 single voice coil(think so)
I have a 2 channel PPI 2100 amp.
The amp is rated at (2x50) 100watts.
Currently i am using only the left channel, nothing is plugged into the right side.
My question is, i assume becuase i a running only one side or one channel on the amp, i am only getting 50 watts out of it. How can i wire it so i am using all 100 watts?
Run them in parallel?
I just dont wanna try something and fry my amp accidentally
Old Feb 19, 2004 | 11:11 AM
LS1 RULZ's Avatar
You need to find out whether or not your amp can be bridged. If it can be, and your sub has a 4ohm voice coil, you're in business.
To bridge the 2 channels together all you have to do is connect the + of the sub to the + of the Left channel. Then connect the - of the sub to the - of the Right channel. Connect the RCA inputs like you always would. The amplifier will combine the signals internally for a mono output.
Old Feb 19, 2004 | 11:44 AM
Acct 23749's Avatar
Yes its a 1040 single 4ohm voice coil. i will try that. thanks!
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
NewsBot
Jan 8, 2015 11:29 PM
Zomie
Jul 21, 2002 08:03 PM
