intrested in LS1 engine (sale)
Old Feb 14, 2004 | 09:24 PM
91Bird305's Avatar
Looking for LS1 short block (LS1 block plus bottom end), If anyone happens to see any good deals or has one of thier own please post. Thanks. (this is Eric's brother)
Old Feb 14, 2004 | 10:51 PM
DEVENOMER's Avatar
I have one but it needs to be looked at and might need to be cleaned up and a few items bought to make it complete!
Old Feb 15, 2004 | 03:02 AM
91Bird305's Avatar
THis is Eric's brother, not Eric. My bro has other things in mind for his car.
Devenmor, is this a ls1 u used to race with?
Old Feb 15, 2004 | 01:11 PM
FSTR-THANU's Avatar
You should check out some of APE's short blocks! Their cheap street 347 is a steal!
Cheap Street 347 Cubic Inch Ls6 Shortblock
$2,799.00 W/cores
· Polished & Magnafluxed Stock Crank
· Diamond Forged Pistons / Flat Tops Or Dish
· Diamond 4130 Chromemoly Wrist Pins
· Diamond Proselect Ring Set / File Fit
· Eagle H Beam Connecting Rods
· Federal Mogul 152m Main Bearings
· Clevite Cb663h Connecting Rod Bearings
· Arp Main Studs
· Blueprinted & Fully Balanced
· Assembled
Options
· Camshafts - $399.00
· Ported & Prepped Oil Pumps - $120.00
· INSTALL FRONT, REAR COVER & OIL PAN - N/C
(CUSTOMER MUST BUY GASKETS OR SEND THEM TO US)
· ARP HEAD STUDS - $219.00
****CORE CHARGES (BLOCK & CRANK) - $700.00****
By the time you have a used motor gone through you may be better off with new and much better components for a few extra bucks. Talk to Chris, Brian or Nick 586-954-3181.
Just a thought!
Tom
Old Feb 15, 2004 | 02:54 PM
DEVENOMER's Avatar
yes it is, it was taken apart a little and now has to have the chambers cleaned! pistons, crank are all there still! its an extra block i have sitting around, was going to clean it up and forge it. But decided to put a built up sbc in my new 95 camaro instead of the ls1! and i got the machine work on my other one with the shop putting the small block together for $850, parts were $1500 for all forged or hardened parts! i can cut you a deal on the block and all the stuff, do you need heads? p.m. me or e-mail me if you dont find anything!
Hotrods&Muscle
Jan 28, 2015 09:35 PM
Hotrods&Muscle
Jan 24, 2015 09:57 PM
Jazsun
Dec 29, 2014 12:14 PM
Hotrods&Muscle
Dec 21, 2014 03:57 PM
