clutch problems
Old Feb 11, 2004 | 06:37 PM
ricetastesbad's Avatar
Question clutch problems
Hey, i have a 2000 z26 m6 and my clutch is gone. I dont want to replace it with the stock one b/c with the plans i have for my car i dont think it will be able to handle it and i dont like it to begin with. Whats the best aftermarket clutch and the strongest that will last??? thanks
Old Feb 11, 2004 | 06:38 PM
funny cars those z26's. sorry the correction is z28
Old Feb 11, 2004 | 06:39 PM
SHIZNIT's Avatar
spec stg 3, search son
Old Feb 11, 2004 | 06:48 PM
Gloveperson's Avatar
I love SLP's clutch package. It is most definatly not a spec stage 3-5 but for the money it is wonderfull.
Old Jan 12, 2007 | 09:37 AM
scof0elife's Avatar
Sorry to slam on your tread but what do you guys think about the stage 1 spec clutch? I can get one for under $200?
Old Jan 12, 2007 | 09:42 AM
teke184's Avatar
why go stronger than you need...
what "plans" do you have? 400hp...500hp...600hp??
probably the most common answer to which clutch is gonna be the Mcloed Street twin.
Old Jan 12, 2007 | 09:45 AM
scof0elife's Avatar
Well my car is a DD and what I have now is longtube headers, CAI and full exhaust. Thats pretty much as performance and working on my suspension right now. So I dont think my car will ever reach 500 HP but maybe around 410. What do you think?
Old Jan 12, 2007 | 09:55 AM
SSpdDmon's Avatar
If you'll only ever reach 410hp at the crank, then I'd suggest going with the factory LS6 clutch in a DD. 410rwhp is a different story. You might want to look at an LS7 clutch and LS2 flywheel setup. Make sure to update the slave hydraulics as well. Got my LS7/LS2+hydraulics setup for less than $600.
BTW, nice to see someone use the search button. It's rare to see a thread back from 3 years ago.
Did you try checking the Drivetrain forum for more suggestions???
http://web.camaross.com/forums/forumdisplay.php?f=44
Old Jan 12, 2007 | 10:16 AM
Sh4Dy's Avatar
Spec is synonymous with "your springs will fall out kid, what r u crazy?
I would go with the LS7 clutch / LS2 flywheel.
Old Jan 12, 2007 | 10:44 AM
Kraest's Avatar
Retired
Ditto to everything.
Spec sucks. The springs blow up, fall out, clutches wear fast or explode.
LS7/LS2.
Mike
Old Jan 12, 2007 | 11:50 AM
teke184's Avatar
the stage 4 doesn't have springs...
as for wear...i guess i'll see...in a few years.
Old Jan 12, 2007 | 12:56 PM
Eric@Victory Racing's Avatar
Either the Textralia 0z700 or the Exo-Skel.
Old Jan 13, 2007 | 10:47 PM
str8-6's Avatar
im running around 380 at the rear wheels, well until my clutch went out the other night when i was racing. i had a ram clutch in it, but after 1 1/2 years its gone. now i think im going to go mcleod, but if not im going stage three. let me just tell you that you might want to go ahead and put the money into a clutch that you might not need now, because if something comes your way, then youll already be set up for it.what ive found out thru my experience is go ahead and get the good ones, just in case.
Old Jan 13, 2007 | 11:20 PM
scof0elife's Avatar
Thanks guys, I was looking into a ls7 with ls2 flywheel but thats bout $600 and thats above my budget right now. Do you think a Centerforce DF? I've read its a pretty good clutch but is it good for DD?
Old Jan 14, 2007 | 01:39 AM
95LT1conv's Avatar
centerforce sucks and so does the sppec stage 1. if you want a good setup, go wit a Mcleod single disc
