cat going?
Old Feb 11, 2004 | 11:01 AM
matt95camaro's Avatar
cat going?
alright, i have a 95 camaro with a 3.4 and i just put in a new engine about 1,100 miles ago. the car n trans has 113,xxx on it and i was just wondering about something. when i start my car in the morning my car will shake a lil more than usual and my exhaust gives like a rumbling/popping sound for a minute or two untill the car is warmed up.. i was wondering if thats because my cats going? i havent noticed this happening till the past few weeks.
Old Feb 13, 2004 | 12:53 PM
deadmeat2004's Avatar
Mine does the same thing, i asked the same question...
Old Feb 18, 2004 | 04:26 PM
fbird95's Avatar
If its a poping doesnt sound like the cat, now a rattling durring warm up, that seems to be metalic, most likely the cat.
Old Feb 19, 2004 | 06:15 PM
stangkilla1's Avatar
That popping could be a nuber of things:
*ignition coils
*running to lean (usually due to a faulty o2 sensor)
*bad plugs
it's probably going to be one of those. Run your car for a couple of minutes and drive around the block. When you park, look under the car at where the Cat sits. If it's red hot and kinda glowing red then it might be stopped up, but that could also be bad coils dumping too much fuel and the excess runs into the exhause causing the cat to heat up (very hot). So check ones on the list above.
Old Feb 20, 2004 | 02:58 PM
2000camarostud's Avatar
Do you notice a decrease in acceleration ESPECIALLY at high RPMS? my car was making the same noise and when i'd get on it at all at high rpms it would feel gutless...come to find out, it WAS the cat, so i had to have it replaced.
Old Feb 24, 2004 | 02:03 PM
blkmaro94's Avatar
Mine went out and I just had it replaced along with the muffler and as soon as I drove the car when it was fixed it ran alot better. Because when i revved it would make a rattiling sound and plus the car was losing alot of power. at high rpms it would die out. and feel gutless. also have someone rev the engine for you and listen by the cat you'll hear the rattiling coming directly from it. and not the engine.
n2oblkz
Oct 12, 2015 01:53 AM
football4life
Oct 4, 2015 07:48 AM
Ks0209
Oct 1, 2015 07:32 AM
Tarizza
3rd Gen / L98 Engine Tech
Sep 20, 2015 03:26 PM
Sep 11, 2015 09:44 AM
