Anyone have pics of their purge valve?
Old Feb 6, 2004 | 06:47 PM
crb4osu's Avatar
Where do most of you put them?
Old Feb 11, 2004 | 02:14 PM
Hawk's Avatar
www.eden.rutgers.edu/~bhawalka/new1.JPG
The purge is mounted with the nitrous noid on the intake, I ran the lines under the cowl and up so it purges straight up in front of the window.
Old Feb 11, 2004 | 08:21 PM
Gold Z's Avatar
Not your typical purge.....http://community.webshots.com/photo/...12648179SEdBhi
Old Feb 14, 2004 | 11:29 AM
JJJ93z's Avatar
no not typical at all! i was wondering what kind of tubing you used from the purge noids out? was it hard to bend? also what kind of fittings are those that screw into the noid? your setup looks great!
Old Feb 14, 2004 | 05:05 PM
Gold Z's Avatar
We used brake line tubing and standard NX fittings. The tubing is easy to bend. I went with a dual purge for looks only. One would have been plenty from a functional viewpoint.
Old Feb 20, 2004 | 09:38 AM
N20Dave's Avatar
http://members.cardomain.com/protouringz
Theres a pic of the purge somewhere in there.
Old Feb 20, 2004 | 10:40 AM
bigdreamZ's Avatar
N20 Daves Camaro
A perfect combination of form and function...
...and an underbody that you could eat off of!
Old Feb 20, 2004 | 01:36 PM
2Poor4Z's Avatar
HOLY ****!!! Dave your car is the ****ing **** dude.. 250hp fogger? hot damn
Old Feb 26, 2004 | 10:25 AM
N20Dave's Avatar
Thank you. I've not pulled the trigger on it yet but spring is a comin.......
Old Feb 26, 2004 | 01:12 PM
2Poor4Z's Avatar
expected ET?
Old Feb 27, 2004 | 07:43 AM
N20Dave's Avatar
Maybe mid 11's on motor. I was thinking mid 10's on a 150 and 10.00's on the 250 depending on traction and other variables. I'd like to see a 9.xx but with the car being dual purpose I'm not sure if it can 60' good enough to get there. It should have wicked mph though. The motoris a 396 with well ported factory castings. They flow in the 290 range, it's got a 248/258 .609 110 cam. Not the best lsa for nitrous but it's driven n/a most of the time. Close to 12-1 comp. It should be making 500 or so at the flywheel on the motor then add another 250........
Old Feb 27, 2004 | 05:21 PM
JodyJ's Avatar
Here's my simple setup.
http://jody.dltechnologies.com/share...Solenoid-A.JPG
http://jody.dltechnologies.com/share...Solenoid-B.JPG
Jody J.
Fastbird93
Apr 9, 2016 07:01 PM
Mar 13, 2016 03:39 PM
Jlo
Feb 3, 2015 09:41 PM
HectorM52
Jan 30, 2015 11:34 PM
blac94Z
Nov 28, 2014 01:53 PM
