How hard is it to install a complete n2o system?
Old Feb 6, 2004 | 04:30 PM
crb4osu's Avatar
I have the 5177 kit, MSD window switch, bottle warmer and bottle opener and soon to get a retard box. How many hours will this take and how hard is it to install? Any tips? Thanks
Old Feb 6, 2004 | 10:12 PM
RacinLT1's Avatar
how many hours depends on how meticulous you are. the neater you make t,the longer it takes.
experienced person could pull it off in a few hours,beginners plan a day.
Old Feb 7, 2004 | 02:25 PM
juiced_lt1's Avatar
unhook your battery...you'll be fine then.
Old Feb 8, 2004 | 06:42 PM
DrewHMS97SS's Avatar
use spit loom so it looks nice
Old Feb 11, 2004 | 02:13 PM
Hawk's Avatar
not hard, just time consuming to get it nice and neat. Also, my tip to you is to make sure all your connections are soldered and they are all 100% up to spec. You don't want any wiring problems, better to do a good job first them to get hard to diagnose problems in the future as well as catastrophic failures if for example the fuel solenoid failed to function due to faulty wiring. Good luck
Brian
Old Feb 11, 2004 | 09:10 PM
juiced_lt1's Avatar
Yeah, make sure your ground wires are good too...when it gets cold sometimes the ground doesn't work too good if it's not on a good connection. I know this from experience
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Collector Car
Jan 5, 2015 10:58 AM
Vokabulis
Jul 25, 2002 05:46 AM
