question about purge kit
Old Feb 5, 2004 | 09:45 PM
blazzinbird's Avatar
is there a way to make it spray 2 stream instead of 1?
if so how hard is it to do
Old Feb 5, 2004 | 10:43 PM
RacinLT1's Avatar
it's easy,just have to run a compression T fitting and 2 lines.
basically remove the fitting from the solenoid,replace it with a 2,and then run 2 lines.
Old Feb 8, 2004 | 01:02 AM
is this purge kit ok
http://cgi.ebay.com/ebaymotors/ws/eB...tem=2458378687
and where can i get the t fitting, and what size should it be, and what size tubing do i need
Old Feb 8, 2004 | 11:36 AM
RacinLT1's Avatar
yeah thats not bad,it'll work.
also go here for a simple dual spray setup....same company sells it...http://www.dynotune.org/store/Script...p?idproduct=34
Old Feb 8, 2004 | 02:15 PM
DrewHMS97SS's Avatar
i dont think i would buy one using plastic tube.
Jan 23, 2015 01:13 PM
alphaauto
Jan 23, 2015 07:42 AM
CARiD
Jan 14, 2015 04:00 AM
Queens94z28
Dec 20, 2014 09:11 PM
Dec 4, 2014 11:56 AM
