Anyone installed '69 vintage Z/28 emblems on a 4th generation Z ?
Old Jul 29, 2002 | 08:22 PM
JETMAN95Z28's Avatar
Question Anyone installed '69 vintage Z/28 emblems on a 4th generation Z ?
I've alwasy LOVED the look of the older style Z/28 emblems and am thinking of putting a set on my Black '96 Z. The factory black emblems are practically invisible on the black paint. Has anyone else made this addition? What kind of 2-sided tape does the factory used to attach these? What do I use to attach the new (old) emblems? How hard is it to remove the stock ones??? Anything a blow dryer can't remove?? ANY input would be greatly appreciated!!!
Old Jul 29, 2002 | 08:57 PM
W7Z28's Avatar
honestly i like the idea i think it would look good when and if you do it post some pics
97 Z28 t top a4 kenwood cd, alpine super tweeters 2 pair 6 1/2component speakers 4" alpines,v 12 alpine amp,jl 2 rockford xlc 12" sub,jl 500/1 amp,sticky tires,slp cai,160 stat,slp manual fan switch,tb bypass and air foil,hotchkis stb,jet chip stage 2 (removed do to powerloss )module ,flow master exhaust,cross drilled rotors,and auto optics headlight conversion 342's comeing soon.
Old Jul 29, 2002 | 09:08 PM
Deadcarny's Avatar
i removed my stock emblems today and will be putting the 1st gen emblems on before the autofair in september. i will definately post pics! (my car is silver)
Old Jul 29, 2002 | 09:09 PM
350 HRSS's Avatar
That would be me
And I get a lot of compliments
If someone can host the pics, I will send them Get the 69 grill emblems. They are larger, and look much better!
Old Jul 29, 2002 | 09:16 PM
SS BadRag's Avatar
I'v got a 67/68 SS emblem on my billet grill.
Check out NPD for the emblems.
97'Black SS Droptop,#2893,(1of31),320HP,LT1,A4,Headers,SLP Goodies.....
ssbadrag
Old Jul 29, 2002 | 10:13 PM
Ernster500's Avatar
Here is a link for you I came across a while back. One of the many things I have wanted to do...
Phil did a nice job...
http://www.freewebz.com/philsz28/69z28emblemsmod.htm
Ernie's 1994 Camaro Z28 Black, T-Tops, M6: ! CAGS; TB Bypass; ! MAF Scrn; LT4 KM; Pro 5.0; Jamex STB; DMS SFCs; SLP CAI; HPP+; 160 'stat; 3.73s; TA Cover, Jamex Springs; + Fog Lamps; B&M Shifter ****; Chrome Z28 Overlays; Chrome CAMARO Inlay; Black Mast Power Antenna; Sequential Tail Lights, ROH RT 17x9 in Black Ice -w- 275/40-17 RE730s; Air Foil; Jet-Hot Hooker Shorty Headers (on-order); Hooker Cat-Back (on-order); Taylor Over-the-Valve-Cover Wires (on-order);
Old Jul 30, 2002 | 12:17 AM
fastcamz28's Avatar
Cool
I have them on my '94 Z28. Have pictures on a disk and as soon as I learn how to post them, they will be up for viewing. Could use some tech assistance!! Thanks!!
Old Jul 30, 2002 | 09:41 AM
ZForce's Avatar
Pictures in sig under modifications.
69 Z28 fender emblems and 69 Z28 Tail light Panel emblem on Red 98 Z28.
Robert
1998 Camaro Z-28 M6
MODIFICATIONS
Engine: GMS Lid, FTRA, TByrne Red MAF Ends, BBK 80mm TB, 160* Thermo, 1 piece TB Bypass, SLP Fan Control Switch w/LED's
Drivetrain: SLP Short Throw Shifter, Lou's Short Stick w/ROBMOD, !CAGS
Suspension: BMR Dbl. Adjustable PHB, BMR LCA, BMR STB, KVR Cross Drilled (F/R)
Appearance: SLP Bowtie Grille, Clear Corners, T/A Power Antenna, Tinted Windows, Zaino
13.24 @107.75 w/2.17 60'
311rwhp / 328rwtq Dyno Graph
Pictures
Old Jul 30, 2002 | 09:45 AM
Grn96Z's Avatar
Cool
Ive had them on my car for about a year now, the first day I had them on a guy in a 2000 SS pulled up next to me and told me they looked amazing, then proceeded to put about 5 car lengths on me, lol. It was cool anyway
Old Jul 30, 2002 | 10:59 AM
Thanks for the input guys. No one mentioned on how to get the old emblems off as well as what I should use to re-attach the new emblems. Any ideas?? I would imagine the heat of a blow dryer would be enough to get the 2 sided tape off of the stockers, but where do you get the stuff to put them back on??
Old Jul 30, 2002 | 02:05 PM
AlexDeLarge's Avatar
Cool
<font face="Verdana, Arial" size="2">Originally posted by JETMAN95Z28:
How hard is it to remove the stock ones??? Anything a blow dryer can't remove?? ANY input would be greatly appreciated!!!</font>
I believe you can take them off using a hair drier and then gently applying a fishing line.
By the way, will you be interested in selling your stock Z28 badges afterwards?
Two of mine were stolen by some jerks and I've looking forward to get some new ones(they did a good job though, not messing with the finishing)
Old Jul 30, 2002 | 04:47 PM
thanks for the fishing line input... hadn't thought of that. Just figured I'd get it soft enough with heat, and pry it back SLOWLY with a fingernail or other non-paint scarring material. also thanks, but I'll probably keep my old emblems just in case the possible "next owner" isn't as fond of my ideas as I am. I've saved all the stock parts from my "customizations" so far.
Old Jul 30, 2002 | 05:26 PM
CARGASM's Avatar
I have to say that I was one of the originals to do this about 4 years ago, and I have never had anything but compliments. I have some pics in my sig but as far as I can remember there aren't any close-ups.
As much as I want to tell everyone not to do it, so that I can stay unique, it does look really nice.
As for install, I got originals from a '68 Z. The backs had mounting posts that I cut off and filed down. The emblems I found are bent at the wrong angle, so you will need to bend them accordingly. I used two layers of 3M double sided tape to attach them, because the backs were grooved and I didn't want the metal touching the paint.
I found my emblems at a Camaro swap meet, however I think that they are easy to come by now from places like Year One.
~Adam
Old Jul 30, 2002 | 10:49 PM
ZForce's Avatar
I bought mine from www.camarosandclassics.com
They are OEM and cost a little more.
I used a razor blade that is made for removing such item - not sure where you'd get them because I got mine from the paint shop, but they are super thin, flexable and about 6 inches long x 1 inch wide.
On the 69 emblems, I also cut the studs off on the fender emblems and had to flatten them out as they are made to fit the contour of the 69 fender. I used a jack press we have at work to make them flat - just wrapped them up well and placed them between 2 steel plates and pressed them nice and flat.
[This message has been edited by ZForce (edited July 30, 2002).]
Old Jul 30, 2002 | 11:22 PM
OctaneZ28's Avatar
Disciple
Thumbs up
I just bought a billet grill for my car and mounted a 1969 Z/28 emblem in the middle of it.. when I get the grill on the car I'll be sure to post pictures.
I'm driving with no grill right now, I kinda like the look, but the billet grill on there will look better
www.CamaroHighway.com
Yahoo! Group - Chevy Camaro Z28
2001 Camaro Z28 A4 2.73 - Navy Blue Metallic - my 5th Camaro!
Stock Dyno: 293HP/317TQ
Stock 1/4 Mile: 13.573 @ 103.18 (60ft 2.054)
Mods: SLP CAI, K&N Filter, SLP Loudmouth
Best 1/4 Mile: 13.341 @ 104.38 (60ft 2.003)
