Nitrous
Old Jan 29, 2004 | 09:38 PM
CodysRedZ's Avatar
Nitrous
Im wanting to get the tnt nitrous wet kit(the plate system). I plan on running 75 100 shot at the most. I dont think it comes with an inline fuel pump. Do i need an inline fuel pump to compensate for that extra juice?? Or can i leave it stock?? thanks
Old Jan 29, 2004 | 11:40 PM
S.J.S.'s Avatar
You'll need another pump. But what you really should do is post this in the N2O Tech section.
Old Jan 29, 2004 | 11:46 PM
jonaddis84's Avatar
An "in working order" stock pump will suffice for that small a shot. Dont want the pump to quit in the middle of sprayin though
As long as you wire in a fuel press switch you wont have a prob with a stock pump though
Old Jan 30, 2004 | 01:55 AM
nitropatch's Avatar
Talking
the stock fuel pump will hold up tp a 150 shot, but if you plan on running a 100 shot i would invest in a adj furl pressure regulator, nice insurence.
Old Jan 30, 2004 | 08:34 AM
RacinLT1's Avatar
afpr isnt worth much insurance if the pump is old or weak. it doesnt offer much if it's a new pump either.
the stock pump is fine for up to the 100 shot,but depending on age of car and mileage,you might want to consider going with as new pump.
Old Jan 30, 2004 | 11:42 AM
nitropatch's Avatar
it is always good to have a afpr when you are doing a wet kit if you dont then you have a good chance of somthing blowing.
Old Jan 30, 2004 | 12:28 PM
RacinLT1's Avatar
nitropatch,please explain what good an afpr is going to do when our cars can read the higher pressure and adjust the injector pulsewidth accordingly to compensate for the higher pressure that isnt needed.
i have been 11.0's consistently with a stock pressure regulator and injectors with my wet kit. rskrause was making 600+rwhp with a stock fpr,so im not sure where you think it is needed to prevent something blowing up. under WOT the stock regulator opens up(increasing pressure,and the pcm knows this),and most everyone i know sprays under wot.
a new fuel pump s better insurance then an afpr for a wet nitrous kit,as well as a fuel pressure safety switch.
Old Jan 30, 2004 | 12:52 PM
gb95zconv's Avatar
I wouldnt push the stock pump past a 100 shot and an AFPR is not going to give you any insurance......a fuel pressure cutoff switch will.
Old Jan 30, 2004 | 02:29 PM
nitropatch's Avatar
then i guess you guys are lucky or somthing because lots of people that i have seen run 10's and 11's have afpr because the stock one doesnt have enough pressure, the afpr will send the neccessary fuel so that the pulse will stay the same, more efficiant. but thats just what some of us LT1 guys think, maybe the stock one will work for you all but once you do more stuff you will have to get bigger injectors correct? all i do is turn my pressure up and everything is fine. but the afpr is also insurence when you have a blower. and just get a micro-switch so when you hit WOT then system works, alot safer that or a window-switch.
Old Jan 30, 2004 | 02:41 PM
atljar's Avatar
Quick, run! Find your flame suit. Going to need it REALLY shortly....
Old Jan 30, 2004 | 02:46 PM
nitropatch's Avatar
Old Jan 30, 2004 | 03:09 PM
RacinLT1's Avatar
problem is,the pulse WONT stay the same unless you reprogram the injector constant. turn the pressure up and risk locking a stock injector? thats not smart.
you might want to read this thread.....http://web.camaross.com/forums/showt...hreadid=218282
Old Jan 30, 2004 | 03:11 PM
DrewHMS97SS's Avatar
hes saying that people are going to start talking **** about what you had to say.
the AFPR is a good idea if you have the extra money, I would personally put in a walbro pump first.
Old Jan 30, 2004 | 03:33 PM
gb95zconv's Avatar
Ok I was just gonna put up the BS flag but instead Ill ask.....if the stock fuel pump can only deliver 37-38 psi when the fuel silinoid is open for a 100hp wet shot how in the heck is a AFPR gonna incraese the fuel pressure when the pressure is allready below the stockers limit ? The stock pump can only pump so much fuel and thats the point.
Old Jan 30, 2004 | 04:26 PM
nitropatch's Avatar
well i dont know what kind of fuel pump you have for stock but the one i had was good to 38-44psi at least thats what it said in my cars book manule, but i put a little better pump in mine i got the one from TPIS that supports up to 450 hp little better then the stock pump. but after reading the other post about the regulators i guess leaning it out a bit will help out at WOT due to the computer. when i squeezed my motor i did a 100 shot tons of times on satock pump and regulator but when i put the afpr in i felt more of a pull on the top end so on some cars it works better some it dont i guess.
