I think I found the problem - the computer
Old Jan 23, 2004 | 01:04 PM
Pro
Guest
Posts: n/a
I finally had time today and smacked the ECM around (under the dash). First, i tried to start it, no start. So, I took the dash piece off, tapped around the whole area (silver box right?), adjusting wiring, etc, then sstarted it up. Ran great (little hessitation because of prior flooding).
I ran it for 30 seconds and beat on the dash area at the same time, and it didnt cut out or stall.
So I dunno, but at least I see that it is alive now.
It seems to make sense that it is the computer. When the problems began, i would experience:
1)No codes being stored even though CEL came on
2)300-400rpm semi-rough idle
3)Speedometer not working
4)Huge loss of power
5)Gasoline smell
6)electric fans come on randomly
7)takes FOREVER to warm up to operating temp (seriously like 45 minutes stop and go traffic)
These problems would occur in spurts - IE car would work fine, then the engine light would click on and all of the above would happen. Then it would go away randomly. (only until a few days ago when it wouldnt even start).
So I guess I need a new comp.
Old Jan 24, 2004 | 12:08 AM
Pro
Guest
Posts: n/a
Doesnt seem to have the power it use to have though.
Anyway to tell if a prom is stock or not? Since I changed out the comps obviously I had to swap chips also.
Old Jan 24, 2004 | 10:24 AM
lt1g3n's Avatar
you changed your pcm ? what year is your car, and what year did the newer one come out of
-- 91 Z -- ok :P what year did the other one come out of, same system and all?
Old Jan 24, 2004 | 11:16 AM
Pro
Guest
Posts: n/a
I bought a rebuilt one from Advance AP. I switched proms and was on my way.
Old Jan 24, 2004 | 02:29 PM
dj haf's Avatar
so everything works perfect now?
Old Jan 24, 2004 | 03:54 PM
lt1g3n's Avatar
hows it running now?
Old Jan 24, 2004 | 10:01 PM
Pro
Guest
Posts: n/a
I took it for a 30 min test drive today. Not a single problem. Perfect idle.
Course it had way less power, probably because of the fouled up plugs.
Old Jan 24, 2004 | 10:24 PM
aklim's Avatar
Tried changning the plugs to see if that fixes anything? Even if they are fouled out, shouldn't they have burnt off by now?
Old Jan 24, 2004 | 11:19 PM
ThirdgenTa's Avatar
I had that exact same problem. To see if it was the computer, I just tapped on it and it would either die or idle rougher. I got a new computer and it runs fine. I had all the same symptoms. Couldn't read codes, fan goes on automatically, car has no power and idles at 300 rpm.
Old Jan 24, 2004 | 11:24 PM
Pro
Guest
Posts: n/a
Check these pics again:
http://webpages.acs.ttu.edu/blincoln/comp/IMG_0010.jpg
http://webpages.acs.ttu.edu/blincoln/comp/IMG_0011.jpg
I know the stuff crumbles over time, but it sure looks something got all over it (IE water).
BTW the passenger side window does leak air around the side view mirror - when it rains it gets covered up. Im just wondering if the guy that owned it before me let it sit out in the rain and drip wet.
Old Jan 24, 2004 | 11:39 PM
ThirdgenTa's Avatar
Could have been from a heater core that went some time ago
Old Jan 25, 2004 | 12:12 AM
Pro
Guest
Posts: n/a
Wow now that I think about it yea that is one thing he said he replaced.
Old Jan 29, 2004 | 11:12 AM
Pro
Guest
Posts: n/a
Do I need to go through replacing these spark plugs again?
They have about 200 miles (3 months) on them, but I pulled cylinder 1's spark plug out (like I mentioned above) and it sure was pretty bad. It should burn off shouldnt it (assuming the motor isn't running rich any longer, which it doesnt seem to).
Also what is the normal idle speed for the motor? It runs at about 1200-1300rpm during warmup, and idles at 0mph in drive at about 700.
Old Jan 29, 2004 | 11:25 AM
dj haf's Avatar
idle should be around 600 on an auto
