Old 06-20-2002, 05:04 AM   #1
ZBLKHELLRZR
Question Good coil over kit?
I've already have the eibach sportline and HD bilsteins. What's a good coilover kit out there? LG sells the entire assembly but don't need that since I've got the bilsteins already.
Ground control's website is down as well as Global's. Does ground control just adjust height or does it improve handling aspects as well? There's seems reasonable in price and I don't have any info on GW's product or pricing.
Thanks for any info.
93Zm6 Blk TT stk 3.23's
Engine mods:
Balanced & Blue printed 396 Forged Lunati internals, Stage II Heads, Taylor wires, NGK TR55's, Accel 300+ & coil, 95+ opticrap, AS&M 58mm TB, ATI damper, AFR Rev Kit, FLP's & Borla exhaust w/top flight corvette cockpit exhaust adj, Metco AFPR, Accel 30lb inj, Ed Wright Chip, 160 stat, Hurst Pro Shifter,
Mcleod Street twin & alum fly, TPIS 3.5 DS, T/A Cover w/ stud kit
Susp mods: Flowtech adj. TA, KB SFC& 3 PT STB, Eibach sportline springs, Bilsteins shocks, Hotchkis PHR & LCA w/ Spohn LCAB, Poly tranny mount, Suspension tech sway bars 35&25mm, Baer bump steer rods, Baer Track system 13"F 11.7"R drilled/slotted/zinc plated, steel braided lines
Cosm mods:
Ultra Z hood(funtional)K&N, G2 5" rear spoiler & front Gfx, Rytek headlights(oval version),DGmotorsports carbon fiber dual foglights, G2 world challenge wheels 17x9.5 Pwdr coated BLK, Falken 45 ZR17's 275/40, RK smoke signal covers, fire ext, chrome throttle cover, chrome fuse box, chrome LT1 badges, carbon fiber emblem
Interior: Corbeau Targa RS seats & Harness, G2 Harness Bar, RK Wht face gauge, G2 pedals & sills,
Auto Lite Oil, Tranny temp guage, & FP guage
Future mods: A-Arms, ext fuel pump, gauges
__________________
93 Blown, Poked & Stroked
ZBLKHELLRZR is offline   Reply With Quote
Old 06-20-2002, 03:04 PM   #2
Dr.Mudge
They are mainly for your height adjustments and putting in whatever spring you want. I believe they are also lighter than the stock coil-over.
__________________
98 Z28 M6 - 01 R6
An educated mind is a mind that knows that education never ends -unknown
Dr.Mudge is offline   Reply With Quote
Old 06-20-2002, 03:12 PM   #3
IROCrdracer
Thumbs up
ZBLKHELLRZR- I have the GC kit isntalled. Check my sig for pics. They will customize it to match your intent with your car. You can adjust ride height and firmness. I also "scaled" the car for proper balance with me in the drivers seat. Nice kit. I also popped for their camber plates.
90 IROC,394 ci,vortech,SR intake, Accel DFI, MSD 72lb. injectors,Accel injector cntrl,Tremec TKO, 9" Ford,NX 150 HP shot, Spohn adj ctrl arms-sway bars-race tqe arm-,Ground Control coil overs & camber plates,EDL tower brace, roll bar,Kirkey seat
my pics
__________________
90 IROC,390 ci, YS Trim w/10 rib belt, Edel Spr Victr converted to EFI by CFM Performance, Accel 1550 CFM TB, Accel VII DFI, alm Dart 230 CC hand ported by CFM, Aeromotive 11104 pump,Aero regulator, alm fuel cell,MSD 72lb. injectors, Comp solid roller-300/308, 575/575 lift 114 ls, Tremec TKO II, 9" Ford,Spohn stuff,Ground Control coil overs & camber plates,Edel tower brace, 8pt. roll bar,Kirkey rr seat, and more
649 RWHP@6600 RPM
12 PSI (last year)
580 LB. FT @4400
my pics
Road America
traction issues
2003 SORC King of the Hill 1/2 Mile 147.5 MPH
www.sorcrace.com
IROCrdracer is offline   Reply With Quote
Old 06-21-2002, 01:58 AM   #4
ZBLKHELLRZR
Thumbs up
IROC nice pics. Is the camber plate needed? I thought 4th gens didn't require that. I'm not sure so you can correct me if I'm wrong. So how is the ride w/ those 1100lb 'rs up front?
More than sure I'm going this route just wanted others opinions 1st. She's a daily every now and then if they weather is nice. But she's goin to be for the track and long runs on the autobahn mainly w/ the country side roads as appetizers. Beautiful back roads over here.
Thanks
__________________
Old 06-21-2002, 06:33 PM   #5
JordonMusser
Veteran Member
you obviously wouldn't run a spring that stiff on a 4th gen..
anywho, I use GCs.. i like them very much... cheap, and they do the job!
-94 Black T-Topped Z28 M6, 10s, and daily driven!
-96 CBR F3, modded of course
-92 Talon Tsi AWD, also too many mods..
-99 Tony Kart
http://www.fastblackcar.com
__________________
Let's go Grand-Am Koni Challenge racing with a couple of kick butt Chevrolet Camaros:
http://www.momentumracegroup.com
JordonMusser is offline   Reply With Quote
Old 06-23-2002, 06:41 AM   #6
ZBLKHELLRZR
Thanks Jordon, purchasing them next month!
__________________
Old 06-24-2002, 04:09 AM   #7
ZBLKHELLRZR
Question
So what's a good spring rate for the front? I've been in a car w/ 590lb up front but that wasn't a coil over setup either. I don't know what the rear was but it felt really good.
What are some of your setups like?
__________________
Reply Post New Thread
Bookmarks
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Forums Directory
