Alignment after lowering- is it needed?
Old Jan 20, 2004 | 06:54 PM
Scott 97 Z28's Avatar
Just wondering how important it is to have an alignment done after lowering the car. I don't see what would change as long as you don't make any adjustments. Any input is appreciated.
Old Jan 20, 2004 | 08:07 PM
Sam Strano's Avatar
Both camber and toe change when you change ride height. Caster too, but to a much lesser degree. If you don't align it, you will destroy tires and it'll drive terribly.
Old Jan 21, 2004 | 04:22 PM
bruecksteve's Avatar
Sam, does it move toward toe out when you lower the ride height?
Old Jan 21, 2004 | 04:58 PM
Sam Strano's Avatar
Yep, the more negative camber you gain, the more toe out you get. Since you gain negative camber with lower height, the more toe-out you get.
FYI, I changed my camber from -.7 and -1.1 to -1.2 and -1.6 the other day. My toe out went from 3/32 total out to (get this) 1-1/16" total out.
Old Jan 21, 2004 | 05:05 PM
Is this the new ESP car? Coming down with cheater sway bars on huh???
Old Jan 21, 2004 | 05:14 PM
Sam Strano's Avatar
Yes, this would be a 2001 Camaro now mostly setup for ESP.... See you on the 14th!
I'm coming down with EVERYTHING, every bar, rear springs, three sets of tires.....
Old Jan 21, 2004 | 06:34 PM
You bringing S04's???
Old Jan 21, 2004 | 06:39 PM
Sam Strano's Avatar
yes
Old Jan 21, 2004 | 06:44 PM
I still haven't seen the S04 price for a 315 on Tire Rack's site yet. Any idea?? (Maybe I should say "my" price! ) The V710's are $203 plus $15 for heat cycling.
Old Jan 21, 2004 | 06:52 PM
Sam Strano's Avatar
I don't know that they are out yet. FWIW, I buy my Hoosier's from Tom @ Mid Atlantic Motorsport (574-243-5553). He busts his ***, and travels to most every big event. He also can deliver tires to events and mount them too. I'd recommend calling Tom, and even if you don't, I wouldn't spend money on heat cycling them. Just MHO though.
Old Jan 21, 2004 | 07:23 PM
Why no heat cycling?
Old Jan 22, 2004 | 09:51 AM
Xscream's Avatar
If your buying the 04's get them directly from Hoosier (unless you get a discount at Tirerack). The 04's are within 5 dollars of the 03's per Hoosier's pricing. I have always been able to get tires about 10-15 bucks cheaper from Hoosier directly than though Tirerack. The only thing that sucks is you can't get them heat cycled.
Parts Wanted
Mar 17, 2015 11:24 PM
HectorM52
Parts Wanted
Feb 11, 2015 09:33 AM
Hurin
Dec 13, 2014 07:38 PM
NED4SPD
Sep 16, 2002 10:45 PM
mjcent922
Jul 27, 2002 12:42 PM
