01-20-2004, 12:39 PM
Need Some Part #'S
I need the part # for the Driving lamp replacement bulb along with the blinker replacement bulb for the front on a 95 Z. Thanks in advance.
__________________
2000 Camaro SS 6spd.
SLP Lid, True duals w/ Bullets ,BMR Subframes,
QTP 1 3/4 long tubes, Rear Eibachs, BMR STB, BMR Adj. TQ Arm
01-20-2004, 02:37 PM
__________________
01-20-2004, 04:36 PM
Here you go:
Bulbs:
Headlight low beam H4351
Headlight hi beam H4352
Fog Lamp 885
Front parking and turn signal 2397
Tail 194
Tail/stop/turn 2057
Backup 1141
Hi brake 921
Side marker 194
License 194
Cluster 161
Indicator lights 161
High beam indicator 161
Turn signal indicators 161
Heater A/C control 37
Trunk 562
Reading 212-2
Dome 906
Rear courtesy 562
Door courtesy 74
Interior door handle 74
Glove box 194
Console 194
AT Indicator 194
__________________
94Z28, A4, KNFIPK, Edelbrock Shortys, CraneGold 1.6 w/LT4 springs, Borla, MSD6A & Blaster, Moroso 8mm, March 20%UD Damper, Ported/!MAF, TB Bypass, Airfoil, 160*, Goodyear Hi Miler[95 config], LT4KM, Jamex STB, 2.73,T/A Cover, 1LE DS & Trans Mount, BMR LCA&PHR, Powerslots, KVR pads, Earl's SS lines, 2K Zwheels, 150Speedo, ES sway & torque arm bshngs,Mobil1
01-20-2004, 04:40 PM
__________________
07-26-2007, 11:47 PM
Hate to bring an ancient thread back, but just in case...
2397 for our cars has a slotted connector, not a regular bulb twist in type connector. I just blew a couple bucks on the wrong bulb.
__________________
Jason Dove
'95 Dark Metallic Purple Z-28 on '98 Z-28 Rims
383 w/9.5:1 compression, LT4 MTI Ported Heads and Intake, CC305, 12 Bolt and an M6 Swap.
| Thread Tools |
| Display Modes |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
